Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 06-28-2005, 10:47 PM
Obi_Juan Obi_Juan is offline
Send a message via AIM to Obi_Juan Send a message via Yahoo to Obi_Juan
Up grade really = Bad gas milage?
since i am pretty new to this, i am not really sure if this has been discussed. I have a 3G Eclipse GS and the only mod i have right now is a AEM V2 Intake. I really want to fix up my car performance/power more, but i don't really want to lose a lot of miles per gallon. I'm thinking adding a turbocharger or kit would would probably to do, but how about headers and an exhaust? With gas prices skyrocketing in Cali and all, i dont want to be pumping gas more often than not. So does fixing up your car necessarily = lower gas milage?
Old 06-28-2005, 11:06 PM
masokist masokist is offline
Re: Up grade really = Bad gas milage?
not always, such things as your intake system will generally increase gas mileage depending on your setup. a few mods to open up the breathing and let it all flow a little more shuold help gas mileage, but i dont know what a turbo or any sort of kit will do to your gas.
Old 06-29-2005, 08:15 AM
eclipsed4utoo's Avatar
eclipsed4utoo eclipsed4utoo is offline
most of the guys that are running turbos have noticed only as 2-3mpg drop in the gas mileage
Old 06-29-2005, 08:35 AM
drewh4386's Avatar
drewh4386 drewh4386 is offline
Send a message via AIM to drewh4386 Send a message via MSN to drewh4386 Send a message via Yahoo to drewh4386
^ in n00b terms thats a little over or under 1 gallon per fill lost from the original.
....It has been a LONG time...I want to move to FL or Japan.....
Old 06-29-2005, 05:50 PM
Re: Re: Up grade really = Bad gas milage?
so if i just add an exhaust and header, my gas consumption will be pretty much about the same?
Old 06-29-2005, 07:35 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
a short length header and cat-back should be better gas mileage
a long tube header won't help and may hurt and you'll need to tune your car
thats what i was told by another guy w/ short length hy-tech? headers
Don't act like you don't love it.
503/2000
Old 06-29-2005, 10:43 PM
hytech didnt make short length headers....atleast not for the 3G
Old 06-30-2005, 02:59 PM
header, cat-back, and a new air filter shold improve your gas, it may not be a dramatic increase, but it shouldnt hurt, mainly depending on application and use. it also all depends on how it is driven, different styles return different results i have noticed from driving my own car, some day, i get great mileage, other days when i deive a little "too" fast, i wast a LOt of gas.
Old 06-30-2005, 06:23 PM
perna00's Avatar
perna00 perna00 is offline
Send a message via AIM to perna00
here's the info on the gas millage. when ever you make your engine "breath" better, you will use more gas to even out the extra air you're bringing into the engine. every mod with intake, exhaust will use extra gas. There a catch though, now that you get more power, you won't have to push the petal as far down anymore to get the power you're used to. therefore you're saving gas by not having to hold the throttle body open as long.
as for headers, if you aren't going to tune them in with an air/fuel computer, you're going to loss alot of gas in the top end. after you get them tuned in, it'll be close to where it was before for gas millage.
Old 06-30-2005, 07:09 PM
Sleepr awd's Avatar
Re: Re: Re: Up grade really = Bad gas milage?
eh, i'm prolly wrong but he had a 01 GT w/ a short length header of some sort...
503/2000
Old 07-05-2005, 03:13 AM
viet_boiiiii's Avatar
viet_boiiiii viet_boiiiii is offline
Send a message via AIM to viet_boiiiii
Turbo charging your 3g will not effect gas mileage unless you drive it hard. For example if u drive your eclipse on vaccume mode then its at its regular mpg. If your boosting around 2-4 psi then your only taking a little bit of mpg out. If your overboosting like around 10-14 psi then your screwing up your gas mileage real bad. Its also the same without turbo. It just depends on your driving habbit. Sometimes people mod their car and dont even tune it out. They usually just leave it the way it is and run too rich or too lean. The people who knows how to tune cars knows how to save gas because they adjusted it right so the car can run normal/fast without stressing out any parts.
new 2006 Scion tC - 5spd
-magnaflow catback
http://www.cardomain.com/ride/2088489
~~~R.I.P (7-2-05)~~~
1998 Eclipse Gst - 5 spd
