Old 06-28-2005, 10:46 PM
mitchdakid mitchdakid is offline
Question 96 CD PLayer
I have a 96 Blazer LS two door and just recently the stock cd player quit playing cd's. Everything else works fine but it won't play any kind fo cd and after it it says error is spits the cd out. Any ideas of what is going on or is my deck toast.
1967 mustang coupe
new candy apple red paint with charcle striping, 351 windsor rebuilt 100 miles ago, 463 butt gears, B&M QUICK SHIFT, c-4 Transmission, shaved door handles, custom interior - not finished yet, 68 gt wheels-powder coated, slicks for the track, mustang 2 suspension.
1996 Blazer LS 2 door 4wd
aftermarket muffler-Flowmaster 40, cold air intake coming, blazer extreme body kit on it's way also, front has been lowered with tensioners, and rear with a block.
Old 06-28-2005, 10:57 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 96 CD PLayer
get a cleaning kit and clean the laser
1995 Factory Blazer Service Manual for sale, PM if interested.
JC327's Avatar
JC327 JC327 is offline
Once the factory CD player starts acting up, it's pretty much over. It's also far more than it's worth to replace it, unless you can find a used unit. The most economical way to to is with an aftermarket unit, which is not only going to be less expensive but in most cases far better quality than the factory.
Old 06-28-2005, 10:58 PM
JC327's Avatar
Re: Re: 96 CD PLayer
Yes, definitely do that before buying anything. I'm nearly ashamed that I forgot to say that!
Old 06-28-2005, 11:10 PM
BlazerLT's Avatar
AF -Advisor
Re: 96 CD PLayer
Remember that when you change the head nuit, you will have to change the speakers to if you want any decent sound at all.
The stock factory speakers are matched 6 ohm and when you install a standard 4 ohm aftermarket headunit, you will not get the same volume seeing the resistance is higher than the aftermarket head unit is made for.
Old 06-29-2005, 12:34 AM
JC327's Avatar
The stock speakers really do not have much definition, anyway, and if you want good sound they are always the first thing that needs to be changed.
