Old 06-28-2005, 10:27 PM
MitsubishiEclipse MitsubishiEclipse is offline
Question BOVs and Wastegates
when i look at turbo parts online, something tells me that BOVs and wastegates are the same thing. can anyone give me a little info about each one, where they are located and what they do? thank you
Old 06-28-2005, 11:27 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: BOVs and Wastegates
At least lie to me and say you searched but didn't find anything.
blow off valve is in the upper intercooler pipe near the throttle body elbow. it releases boost pressure when the throttle plate closes (when you let off the gas or shift) so that the pressure doesn't hurt the turbo.
wastegate is a valve, mounted in the turbo (internal gate) or on the o2 housing or exhaust manifold (external gate) so that when a certain pressure is reached at it's vacuum source (from boost controller), it opens a valve to redirect exhaust gases away from the turbine wheel, in turn stopping the force that spools up the turbo, and limits the boost of the turbo.
Old 06-29-2005, 06:26 AM
kjewer1 kjewer1 is offline
AF - Advisor
There is a sweet sticky on this topic at www.racingknowledge.org, DSM section, stickied at the top of the topics list. Not sure if that one ended up in a sticky here or not..
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 06-30-2005, 04:09 AM
MoozillaGSX's Avatar
MoozillaGSX MoozillaGSX is offline
Send a message via AIM to MoozillaGSX Send a message via Yahoo to MoozillaGSX
while where in here , i was wondering which is better ....Internal or external waste gates ??? and WHY?
Austin - 95 GSX .
-K&N FIPK.
-Ijnen UICP + Greddy RS BOV.
-Rota Slipstream + yokohoma Es100's.
-Tokico HP Blue's + Springs.
-Power Slot PRO rotors ( slotted+Dimpled ) with Hawk HP Pads.
-Manacore Wires.
( got a 20g and the works in the clothset )
Old 07-01-2005, 10:21 AM
AF - Advisor
Externals are better. Superior boost control. Larger valve, stiffer springs (up to 21-22 psi), no shyte arms or brackets to flex, etc.
Kevin Jewer
Old 07-01-2005, 07:58 PM
i see that good to know , i wanted to ask you about your setup.....do you have a AIM or yahoo IM service you can be reached at ?? i wanted to talk to you about a few things that im buying and i figured it would be easyer to talk instead of through threads.
Austin - 95 GSX .
-K&N FIPK.
-Manacore Wires.
Old 07-01-2005, 10:01 PM
AF - Advisor
I make every effort to avoid all instant messaging services. As soon as I log on, I get bombarded with message windows I would just start a thread, there are plenty of poeple here that can help.
Kevin Jewer
Old 07-02-2005, 09:48 PM
oh i see, alright i was just trying to avoid makeign another thread thats probably already been made several time over since before i was even old enough to drive lol. but i will.
Austin - 95 GSX .
-K&N FIPK.
-Manacore Wires.
