Old 06-28-2005, 10:58 PM
hardcorejuggalo hardcorejuggalo is offline
Send a message via AIM to hardcorejuggalo
Arrow Head Unit Wire Help?
Hey i just got a head unit used off a friend she doesnt have the book anymore and i have never installed a kenwood before, its a Kenwood KDC-MPV7019 well heres the wires that i havent seen before maybe someone can help me out.
ANT CONT dark blue
P. CONT Blue white
MUTE brown
EXT. CONT. pink and black
ILLUMI orange white
Its a Juggalo Thing MCL
Old 06-29-2005, 01:10 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Head Unit Wire Help?
illumination is a wire that gets power when the lights in your car are turned on. It dims the deck so it isnt as bright at night. ext. cont. the pink one, I have no idea. Mute the brown wire hooks to a module I believe that senses when a cell phone call is sent to your car and mutes your radio accordingly. P connect and amp connect are both basically the same thing, I think. Both will have a constant 12 when the deck is on. amp connect is the remote wire for an amp, and p connect I believe is for something along the lines of a power antenna. anyone else like to argue? I'm probably wrong.
Old 06-30-2005, 11:26 AM
K well i just hooked it up last night sodered all the wires tapped them up seperatly then taped them all up to prevent damage well my sister went out for a test ride, and she calls me up saying her sub doesnt work so i dont a quick check on all the amp wires and everything well she went to change the cd to put a bass cd in so we can see if we are getting anything and the led on the amp pops on. as soon as the cd goes in the light goes off. WEIRD so i had to pull the head unit out again and it turns out that the ANT CONT only kicks 12 volts in radio mode which sucked so i found another constant 12v line and hooked it up. I dont think i like kenwood anymore lol im stickin with panasonic.
Old 06-30-2005, 05:17 PM
MStout's Avatar
MStout MStout is offline
You had your amp lead connected to your power antenna, its as simple as that. I had my neon lights hooked up to my headunit power, and when I took out the CD they would shut off. Its about the same deal as that. Its ok to not like Kenwood though, I dont think many people do...except Best Buy. Theyre smart enough to start using Alpine though too.
Old 07-04-2005, 12:49 PM
tblake's Avatar
In God We Trust
hook the amp to the p connect. its specifically for an amp, and will kick out 12V anytime the headunit is turned on. Don't knock the radio because of bad wiring on your part. All radios are going to have the exact same wire colors doing the exact same thing. You wont find an easier one to wire in. They are all going to bne the same.
