I have a 98 Ford Contour 2.0 DOHC 4 cyl and my O2 sensor on bank one is bad... where is bank one???? and do i have 2 02 sensors?
Any help would be appreciated. |
seeing that its a 4 cylinder, you only have 1 bank which is in the front of the car. You should have an upstream and downstream 02 sensor.
![]() "The CEG Nazi" www.contour.org 1996 Ford Contour SE - Sold 3.0L V6 and Arizona Dyno Chip Turbo Kit 364 whp, 410 wtq @ 16 psi and only 4,700 rpms. 1999 Tropic Green SVT Contour - Bone stock and MINT |
Re: 98 Contour 02 Sensors
How do I know which one to replace?? The upstream or the downstream? All the code checker said was 02 sensor on bank one failing. Thank you |
Do you still have the code number on hand? I could tell you then.
