Go Back   Automotive Forums Car Chat > Mitsubishi > Galant
Old 06-28-2005, 09:30 PM
gcmonkeyboy gcmonkeyboy is offline
programming keyless remote for galant
how do i programm the keyless remote for my 2000 mistisbishi galant.
Could use some help pleaseeeeeeeeeeeee
Old 06-30-2005, 03:54 PM
azakram azakram is offline
AH Dealer
Only dealer can do that as of my knowledge.
Old 11-03-2005, 02:05 PM
anjdevil2 anjdevil2 is offline
Re: programming keyless remote for galant
OK you gotta be a little knowledgable for this:
Find your ALDL (computer diagnostic port) short pin #1 to #4
or just ground pin #1
Insert key into ignition - OFF
Within 10 seconds, press hazard switch 6 times
Door should cycle 1 time (lock/unlock)
Press transmitter LOCK 1 time then within 10 seconds hit LOCK 2 times
for additional transmitters repeat above transmitter sequence.
Door locks will cycle on each registration of transmitter
your done...!
Old 11-05-2005, 06:29 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Yup, thats about the same instructions as I have. I did it with a paperclip with one end in each pin slot.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 11-27-2005, 12:30 AM
krayzenvy krayzenvy is offline
Send a message via AIM to krayzenvy
Re: Re: programming keyless remote for galant
A paper clip would work or wire? why does 1 go to terminal 4? has this worked for u? Once procedure complete, paper clip is removed right?
Thanks for your help
your done...!
Old 11-27-2005, 12:17 PM
Re: Re: Re: programming keyless remote for galant
I use a paperclip, I think #1 is a ground, so you ground the #4 terminal and yes remove the paperclip when done
Old 11-29-2005, 06:00 PM
Re: Re: Re: Re: programming keyless remote for galant
Kool, ok paper clip from 1 and 4, lol i hope i don't become remoteless
Thank for your reply, appreciate it Mr. NJ DEVIL!
