Old 06-28-2005, 06:59 PM
jason borne jason borne is offline
only at some speeds
i have a 91 v6 3.1 automatic camaro when i drive and i hit 40-45 60-65 mph it jerks alittle then its ok, no codes come up any help would be appreciated.
Old 06-28-2005, 07:07 PM
I-ROC KID I-ROC KID is offline
Re: only at some speeds
dumb question but does it shift hard
355 small block 4 bolt, 700R4 tranny/w shift kit, elbrock 650 carb, elbrock intake, mild cam, 3.73 posi rear end, 3" cowl hood, 3" exhust, b&m mega shifter, k&n air filter, ac delete
Old 06-28-2005, 07:18 PM
Re: Re: only at some speeds
yes it shifts hard once in awhile it will shift light
Old 06-28-2005, 07:23 PM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Thats just power going back to the wheels, its all good.
Old 06-28-2005, 07:51 PM
its like a constant jerking when it is accelerating dosent seem normal
Old 06-28-2005, 11:19 PM
Question Re: Re: only at some speeds
like its having a hard time trying to change gears.could it be my transmission tourq sensor going bad.............
Old 06-29-2005, 09:14 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
I'd say it's an ignition or fuel related prob.
I'd check the O2 out.
Old 06-29-2005, 01:47 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
the jerking, could it be your torque converter locking and unlocking???? there is a known problem with the cooling fan motor creating a harmonic that the knock sensor interprets as engine knock, and it retards the timing, which causes the converter to unlock, the harmonic goes away, timing is restored, and the converter locks up, then it starts over again. My RS did that at 45mph, i replaced the fan motor, and the problem went away.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 06-29-2005, 01:49 PM
89IROC&RS's Avatar
however if it was what i said, it would happen at a consant speed, not just accelleration. so is it only while accelerating, or is it when you are cruising?
other than that, check your trans fluid level, color, and smell, (not taste lol) if its low, brown, or smells burned, you need a tranny service.
also, have you done any modifications to the drivetrain, such as a higher stall converter, aftermarket rear gears etc. etc.
Old 07-02-2005, 02:38 AM
thank for all the info, i will check the trans fluid first.
Old 08-05-2005, 09:05 PM
first i would like to say thank you for the many reponses.i went out and replaced my oils,filters. everything was fine i still could not find problem.
Old 08-05-2005, 09:12 PM
had to take it to a shop there they ran a scope and computer test check . they found secondary ignition wire failed.they installed new ignition plug wire set. reset ignition timing to factory specs. cleared the codes and now the car runs good...
Old 08-08-2005, 09:40 AM
wrightz28's Avatar
thanks for the update!
