Old 06-28-2005, 04:02 PM
earp earp is offline
oil from top of the motor to carburator
HI everyone, I'm sorry to bother you ... but those guys from Toyota forum are kind of ugly, they or doesn't know or they don't like to answer me.... so it goes...I think this is kind of basic mechanical question...
I got a problem with my corolla. It's has only 50 K miles. Year 1997. It's carburated..
I have noticed that there's a pipe that goes from the engine top to the botton of the carubrator dish (you know, where you place the air filter).
Well, in my car it seems like this pipe runs all the motor oil trough it. Of course, when conected you can see a lot of grey smoke exausting my car. Of course, the air filter is brown filled with oil, dificulting the car to start and to run.
I disnconected it, andd then did a small run, and then i found out that all under the hood was impregnated with tons of oil.
So I wonder, which is the cause and what i may do in order to fix it.
thanks a lot...
EARP..
owner of a Blazer & Corolla.
Old 06-28-2005, 05:09 PM
Tangent Tangent is offline
Re: oil from top of the motor to carburator
That might be from the PCV system which relieves built up crankcase pressure. It's normal for this to have some oil in it but too much could be a sign of blowby from worn piston rings. I recommend you get a compression and leakdown test done on your engine.
Old 06-28-2005, 05:33 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
This is blow by coming through your PCV system.
Tell me this, is your oil over filled?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 06-28-2005, 06:37 PM
thanks guys...
No, the casr was not over filled with oil.. as a matter of fact when the spill under the hood took place the car just had like 2.5 liters out of 4.
so basically, it was running with so few oil...
So... based on so few miles run, do you really think it's a problem of worn piston rings?
or it's more like some valve problem or maybe some stucked worn oil in the oil system ?
thanks again...
Old 06-28-2005, 07:52 PM
BlazerLT's Avatar
AF -Advisor
could be...
Also, what oil do you use?
How old is the oil?
Old 06-29-2005, 11:41 AM
oil is SAE 15-40....
one year old the maximun.. like 7000 miles run...
natural oil, not syntethic..
thanks
Old 06-29-2005, 12:01 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
change your oil!!! patrolium base starts to break down after 3 months (hints the 3 month/3k miles(5k km for your kanuks)) and yes you have blowby, and most likly worn out piston rings if the moter gets caked with oil after a few miles run, but worn out rings at 50k is very unlikly... but being that low on oil it is verry possible
Old 06-29-2005, 01:39 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: oil from top of the motor to carburator
Stop spreading the 3k oil change myth and get with the times.
Oil does NOT break down after 3 months so get that out of your head.
Earp,
Start using the proper oil grade for your motor. 15w40 in a motor designed for 10w or 5w30 is really stupid and increases startup damage and results in too high of oil pressure.
Also, consult your manual as to how much oil goes in with a filter change.
And start using a 10w30 would ya. Castrol GTX is a fine oil for your truck.
Old 07-02-2005, 08:11 PM
is there any way this same effect could be happening because some dirt stuck on the oil path?
thanks..
Old 07-03-2005, 02:13 AM
Sure. If dirt clogged an oil line you might have a cylinder that isn't getting properly oiled and caused premature wear on the rings. Once that happens you get the blowby and you get your symptoms.
Old 07-03-2005, 04:23 PM
BlazerLT's Avatar
AF -Advisor
thanks..
No.....
How much oil do you use when you change your oil?
