Old 06-28-2005, 03:10 PM
madaddy madaddy is offline
I can see the starter...
could someone explain how it is removed and how easy the task is. the dealer quoted $124 for labor so I am curious on how big of a job it is. I can only see one of the bolts that hold it on and I imagine there are at least two if not three. thanks in advance
Old 06-28-2005, 10:55 PM
waltham41 waltham41 is offline
what year what engine?????
Old 06-29-2005, 06:45 AM
1997 with the 3.8 L
Old 06-29-2005, 01:52 PM
buzzsaw28 buzzsaw28 is offline
It's not too bad to remove the starter but it is a pain in the backside to get the new one back on. Helps to have a good tool kit with some universal joint socket adapters. It took me about 2 hours to do the job myself and a lot of mumbling and kicking and several nicks and cuts to my hands because the space is so tight. If you have large hands I would advise having it done, if you have patience and small to medium sized hands it's not that bad.
Old 06-30-2005, 12:36 PM
thanks for input
received a quote of $65 plus the part so I am going to get my checkbook out
Old 07-02-2005, 01:22 PM
TurboDuck's Avatar
TurboDuck TurboDuck is offline
Re: thanks for input
Not a bad job at all. (2) bolts, 15mm wrench, and about 20-30 minutes to change one. The Nippon starter solenoid can be fixed for about 10$ with a new contact kit....
Good luck, Gary.
