Go Back   Automotive Forums Car Chat > Ford > Contour
Old 06-28-2005, 03:01 PM
CanuckNewf CanuckNewf is offline
Question 98 Contour won't turn over
Went to start the car this morning. No turnover. Still has original Ford battery. Took it out and put it on my tester which diagnosed it as bad. (Just died after 7-8 years I guess.. understandable)
Took it to Canadian Tire. On their tester... confirmed... bad batter.
Bought a new replacement battery. Brought it home, cleaned the battery cables, put it in... turned the key and... NOTHING (except power to radio, clock, etc) Still no turnover, just single "clicks".
Took the new battery out and put it on my tester. Showed 12.4 volts and about 75% charged. Just to be safe, I charged to 100%. Put it back in the car. Turned the key... NOTHING. (just the same as before)
Checked the "Power Distribution Box" beside the battery. All fuses appear to be okay.
No symptoms previous to the no turnover this morning.
I'm no mechanic, but I've changed batterys before... not rocket science.
Has something changed in newer cars I should know about?
Something I'm missing?
Any ideas and suggestions would be VERY much appreciated.
Old 06-28-2005, 04:26 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
duratec or zetec?
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 06-28-2005, 05:11 PM
4 Cyl ZETEC
Old 06-28-2005, 05:35 PM
Re: 98 Contour won't turn over
Never mind folks. Tried everything I could from here. Had to get it towed. It's the starter. (Expensive bugger, too)
Thanks anyway.
