Old 06-28-2005, 02:51 PM
cnogood cnogood is offline
Send a message via AIM to cnogood Send a message via Yahoo to cnogood
Gets fire but won't start
I had a new ignition coil and modulator put in my 89 rs 2.8 got out the car came back and it wouldn't start back up. any answer to why
Old 06-28-2005, 02:58 PM
ct91rs ct91rs is offline
Re: Gets fire but won't start
You drove it home, and now it won't start? Did you have any starting problems before? Does it turn over?
Make sure that the wire running from the coil to the distributer is on securely.
Old 06-28-2005, 03:06 PM
Re: Re: Gets fire but won't start
Yea its on there good. yeas it turns over also
Old 06-28-2005, 03:08 PM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
You have checked for fuel, right?
Old 06-28-2005, 03:13 PM
yes plenty of fuel
Old 06-28-2005, 03:19 PM
Do you smell gas after trying to start it for a while? Its not a reliable indicator of proper fuel, but if there' a strong gas smell, its probably an ignition problem.
Pull out a plug (hold it with rubber gloves or insulated pliers) and ground it to the block. Have someone else turn it over, and watch for spark...
Old 06-28-2005, 04:06 PM
Is eating.
Im not talking about your gas tank but getting to your engine, no gas+spark=no start.
Old 01-10-2006, 12:22 AM
BiH BiH is offline
also check your battery first
Old 01-10-2006, 01:19 AM
malletslinger's Avatar
malletslinger malletslinger is offline
Did you try turning your key to start and by-passing your starter with a screwdriver?
You need to be careful while doing this but it could help determine if the problem is electricle.
