Old 06-28-2005, 02:30 PM
CRX-TC CRX-TC is offline
converted to r134 but problems arose
converted my rex with r-134a and 1.5 cans of refrigerant. After the first can I heard the a/c pump finally turn on and cold air blew. But the psi was still not too high so I put another can in and I lost all pressure from a bottom line and now it wont hold pressure it just hisses out. Anyone know how I can get myself out of this or how screwd i am? thanks in advance.
Old 06-28-2005, 03:21 PM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
Re: converted to r134 but problems arose
Sounds you might just have a bad seal or a cracked hose or something. What all did you do for the conversion - I'm thinking of doing the same thing myself - want to know what all is involved.
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 06-28-2005, 04:27 PM
Cool
All the conversion is is a new size fitting. You have to release what is left of the old R-12 and then release the cans into the system while the car is runnin and a/c on full blast. It was really easy and worked great until I lost all pressure. Its gettin mad hot on the east coast, you know? =)
Old 06-28-2005, 04:44 PM
4G4D Store's Avatar
You may have a seal that went out - I've heard the stock rubber seals don't like the r-134a - can't verify it though.
Old 06-28-2005, 09:09 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
I've done it. I replaced all the O-rings, the dryer, the condenser and pipe connecting the lower connection on the condenser to the dryer (because the lower fitting seized and I striped the threads requiring the condenser and lower pipe change). I then brought it to the local A/C shop for the flush, fitting change, and recharge. It works great now. GL
Old 06-28-2005, 10:17 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
did you charge the high side or the low side?
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 06-28-2005, 10:36 PM
Hybrid1990crx's Avatar
you can charge on either side if you have a real ac machine. but i dunno about those shitty DIY ones. Sounds like you have a bad schreader valve in your line, replace it, and make sure you dont get any of that shit in your eye, cause it can freeze it.
Old 06-29-2005, 06:37 AM
charging the high side can ruin the compressor
ZC stuff
Old 06-29-2005, 10:46 AM
you charge on the high side with the car running. i never heard of it ruining the condensor, my teacher at school never talked about it and I took AC twice. The only thing to worry about is high pressures.
Old 06-29-2005, 11:45 AM
4G4D Store's Avatar
Does anybody know what pressures the r12 and r134a run at?
Old 06-29-2005, 12:30 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
my kit came with a gauge with the acceptable pressures in a green zone. ive done this retro to all 6 of the cars ive owned and they lasted me a while and were ICE cold if done correctly. currently my civic was blowinf ice for 2 years until i swapped out my crappy Z6 for something a bit more potent...... but then i chose to not have AC or PS so i dont need it now (and yes the one summer i dont have AC gets consecutive 90+ degree days here in MA..)
