Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 06-28-2005, 01:34 PM
rudy4577 rudy4577 is offline
Engine Humming
I have had a reoccurring noise that only seems to happen once it gets Hot outside, sometimes it happens after I turn on my A/C and other times I may not have run it for a few days while driving and it still happens. I will be sitting at a stoplight and my car starts making a loud humming sound, as long as I am depressing the gas pedal it goes away but as soon as I take my foot off the gas it starts humming again. I took it in twice and the dealer drove it for a day and it never occurred while they drove it (of course), but it very annoying and quite load. Any ideas what may be causing it?
99 Ford Explorer Sport (2 Door) V6
Old 06-28-2005, 06:14 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Engine Humming
Look closely at the Idle Speed Control motor. These will start a harmonic resonance occasionally. Also the hose that goes to the ISC can cause this. Ford has an updated one that has a "muffler" in it to reduce this possibility. The ISC is around 40$ = or -, and the hose is less than 20$
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 06-29-2005, 02:13 PM
snap11 snap11 is offline
humming noise
idel air control valve is bad.cost about $50.00 at auto zone.takes less then 10 minutes to replace.i replaced mine a couple of months ago in my 97 sohc explorer.
Old 07-19-2005, 11:26 PM
Toni Williams Toni Williams is offline
Re: Engine Humming
Would you please let me know if you replaced the idle air control valve or the internal speed control motor and what took care of the humming since my 1999 Ford Explorer SOHC is doing the same thing?
Thanks
Toni
Old 07-20-2005, 07:44 PM
way2old's Avatar
TOKEN HILLBILLY
Re: Engine Humming
Love it when they never reply.
Old 07-20-2005, 09:32 PM
StOAKEd StOAKEd is offline
Could be the transfer case, My truck would do the same thing until i rebuilt the tranfer case and if thats it you'll want to rebuild it too.
Cost of a brand new one from ford= $4600.00 (cdn)
from the wreckers= $850-$1250 pending on the tag #
these prices do not include the $100p/h mechanic
It was actually the sprocket for 2-3 gears (i think) that was damaged as well as a plastic piece on the fork, anyway they cost about $300.00 and I did the labour myself. It was quite a choir but i saved hundreds.
good luck.
Old 07-21-2005, 12:11 AM
asemstr asemstr is offline
Re: Engine Humming
As a old Ford tech I've heard the mateing call of a ISC mtr many times! In some vehicles design mods were required to shut them up, but alot of seemingly docile models will let out a bellow when ISC mtr failure is immenent! Also just a heads up! CMP syncro bushings in 4.0 OHVs have a tendency to screech also!
IS IT FIXXED YET?!
Old 07-30-2005, 08:28 AM
Re: humming noise
The loud humming noise that occurs when it is hot outside was due to the idle air control valve. I had it replaced and the noise went away instantly. When you replace it make sure to use a gasket sealant and the gasket that comes along with the idle air control valve. I now will have to have an engine tune up performed because the car is idling stronger than normal.
