Old 06-28-2005, 10:35 AM
74RR 74RR is offline
Replacing ignition switch?
I need to replace the keyed part of my ignition on my 96 GA. My question is do I need special tools to do this job and does anyone have tips on doing such a job? Thank to all who reply.
Old 06-28-2005, 05:58 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Replacing ignition switch?
Yes, you will first need to disable the air bags so that you don't activate them. You will then need to remove the air bag from the wheel and use a wrench to remove the nut. You will need a steering wheel puller and a lock plate compressor to get the wheel off. Once that is done the rest is easy. You should be able to rent the tools from a local rental place or from Autozone.
Old 06-29-2005, 02:59 AM
Knifeblade Knifeblade is offline
http://www.autozone.com/servlet/UiBr...3d800e5d01.jsp
Like GTP states. I would suggest let a pro deal with it, airbag modules aren't something to just go playing with.
