Go Back   Automotive Forums Car Chat > Honda > CR-V
Old 06-27-2005, 11:09 PM
bronxblaza117 bronxblaza117 is offline
Send a message via AIM to bronxblaza117
gas mileage is bad...
i got a 1999 CRV EX 4WD and i get real bad gas mileage, on sunday i went on a trip, 160 miles, and got round 16 mile per gallon, shouldnt it be way more?
Old 06-28-2005, 08:47 PM
14 views and no feedback...
Old 07-28-2005, 09:15 PM
andrew_alfonso andrew_alfonso is offline
Wow that is some gas guzzler for a 4 cylinder! I had the same problem with my 97 CR-V, here are the few things I did to improve the fuel economy:
1) Changed spark plugs to BOSCH Platinum +4 (I tried Iridiums, Platinum +2, splitfire, etc., and the Platinum +4 works the best for me)
2) Changed to K&N air filter
3) Regular inspection of tire pressure (28-32 psi)
4) When on the highway, I try to keep a steady speed/pace, say 65-75 mph max.
This greatly improved my fuel efficiency considering I have over 120K mi on my CR-V. I hope this might help improving yours.
Old 07-28-2005, 09:51 PM
lamehonda's Avatar
lamehonda lamehonda is offline
Re: gas mileage is bad...
What gas mileage are you getting on a full tank? You can't accurately tell what your mileage is unless you empty the tank and fill it a few times. Take an average and you should get a more accurate number.
Old 02-25-2006, 08:48 AM
Dark Sailor Dark Sailor is offline
I have a '97 CR-V AWD. When I got it used with 115,000 miles, it was getting about 350 miles/tank. In the past two months, my mileage dropped to about 290 per tank. I had a full tune-up done on it and that helped some...I get about 330/tank now. I think that part of the issue may be with the winter weather...perhaps winter fuel additives are affecting mileage. Also, I often let it idle for about 10 minutes in the morning to warm up, and this may be part of the issue, as well. I know that's a simple thing, but it may make some difference.
Old 03-10-2006, 11:02 AM
Bestia Bestia is offline
Excessive idling will increase your fuel consumption. Really, your vehicle is ready to go right at the point the motor has oil presure built up (10 seconds max). If it's really cold outside, drive the vehicle easy for a few miles, to let things reach operating temp.
Old 03-12-2006, 03:36 PM
LSC9901 LSC9901 is offline
I'm in the always cold Northeast and I have a 2001 CRV. I do not let it idle in the morning, unfortunately do almost 90% city driving and still get anywhere from 20-24 MPG's in the winter and better in the summer. While I believe that K&A filters are good the cost versus gain isn't significant enough for me to make the change.
