Old 06-27-2005, 06:40 PM
chronofurb chronofurb is offline
some sort of internal leak?
Ok, to start off, I did a search for this symptom and found nothing. Basically, I have an internal oil leak I believe. I have oil on my spark plugs, and just changed the plugs to see if it would change anything... Nothing happened. Also my gas mileage has gone downt he crapper... I replaced the plugs with delco ones. If anyone knows what may be causing this, I will appreciate it very much
Old 06-27-2005, 07:09 PM
mrfirebird mrfirebird is offline
rings or valve seals. does it smoke all the time or only at start up? does it smoke at all ?
01 F150 Supercrew 4X4
01 F150 4x4 regular cab
67 Honda Superhawk CB77
07 Honda Civic
Old 06-28-2005, 04:40 PM
Re: some sort of internal leak?
it seems to smoke mostly at start up, and putters while idling
Old 06-28-2005, 05:20 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
What year of truck?
What maintanence have you ever done?
Is the smoke black or blue?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 06-28-2005, 05:28 PM
Its a 92 blazer 4wd, I have kept it up to date on all mantenances. Like I just said, I replaced the plugs and gave it a tune up myself. Previously I had an alternator go bad, and had to replace a seal that goes to the remote oil installation under the truck. The smoke is more of a blackis whitish smoke
Old 06-28-2005, 05:36 PM
BlazerLT's Avatar
AF -Advisor
What did this tuneup include?
Old 06-28-2005, 06:11 PM
included changing the spark plugs, changing the oil and the filter. checked the transmission fluid to make sure it was good. Pretty basic
Old 06-28-2005, 06:12 PM
also, I was having problems before I did the tune up. That is why I changed the spark plugs, because I was having some idling problems
Old 06-28-2005, 07:51 PM
BlazerLT's Avatar
AF -Advisor
What about:
1.) the fuel filter
2.) Air Filter
3.) PCV valve
4.) Timing check and adjustment.
5.) Distributor Cap & Rotor
Also, what gap did you gap the plugs to?
Old 06-28-2005, 09:43 PM
well, I gapped the plugs to .o45 like the guy at autozone told me to gap them at, and I have checked any of those other filters, but even if I do change those would those affect the fact that their is an internal leak?
Old 06-28-2005, 09:44 PM
also I know the air filter is good. the internal leak appears to be some kind of oil on the spark plugs I replaced
Old 06-28-2005, 09:55 PM
BlazerLT's Avatar
AF -Advisor
The oil could have come from when you were removing the plugs and there was some oil in the plug holes in the block.
Did you do any of the other stuff I told you to replace ever?
A tuneup is not just plugs and an oil change.
Old 06-29-2005, 01:31 AM
no sir, I have not tried the other stuff before, mainly because I dont know how, do you think it could be easy to learn
Old 06-29-2005, 01:33 AM
another thing I noticed is maybe the plug was not burning correctly. The top part of the plug where the prong is was white, but the rest of the part where it screws into the engine was black and had oil on it
Old 06-29-2005, 01:35 AM
also by timing check, do you mean the serpintine belt, It seems good to me
