My camry passenger side window doesn't work, it doesn't go up. I replace the window regulater with motor and everything for both front doors, the driver side works good now but the passenger side doesn't work. doesn't do anything at all...I checked the fuses and made sure they were all good. Check the Gauge fuse since there is not window fuse listed...all seems good..but the window still doesn't do anything. The master switch works for all other windows includding driver side and both rear windows. The passanger front windows doesn't work from eitherone of them...any sugestions? thankx
Re: My Camry passanger side window won't work!
I am afraid you have a wiring problem. The most likely place to find the problem is where the wire bundle leaves the body and goes to the switches in the drivers door or possibly the same area on the passenger door. The drivers side is more likely as it is flexed each time the door is opened and is used more than the passenger side. I would try manipulating the harness by hand and trying the switch.
check kick panel on pass. side behind it are relays, also check and make sure your plug in for switch on pass. side is connected, if the switch on the pass. side door panel is disconnected the window wont work from master switch.
