Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 06-27-2005, 04:35 PM
Fparente Fparente is offline
Question 97 VW Jetta starter/idle issue
Hello All:
I have a 2.0L/5spd engine and recently had my starter replaced and after doing so my car ran horrible! My idle was perfect before, now it is not in normal conditions. The idle fluctuates between 500-900RPM and sometimes the engine dies out when you are approaching a stop. I have had a tune up 3mths ago on the car before the starter was even an issue (new air/fuel filters, spark plugs, and new water pump at the time).
Does this issue have to deal with anything with the starter? I believe that it might be a "ground on engine/starter ground issue" (grounding-electrical issue w/ starter)? Would the idle even be effected by a new starter? How do I go about fixing my idle issue?
Old 06-27-2005, 11:45 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Check for vacuum leaks. A new starter wont cause any " idle problems"
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
