Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-27-2005, 05:03 PM
nettiebaby24 nettiebaby24 is offline
Unhappy 92 Laser starts/idles at 500rpm/stalls????
Hi Everyone... I'm new to this and not very experienced with cars but I'm trying to learn what might be wrong with my car so I don't get screwed by my mechanic...
I have a 92 Laser RS 5 speed AWD Turbo. A week ago, I started my car but instead of it idleing around 1000rpm like usual... the rpms teetered between 500rpm and 700rpm and then stalled after about 5 seconds. Now once I start my car, I have to keep on the gas so my rpms are around 2000 just to get going and everytime I slow down too much or come to a stop, I stall and I've gotta start my car again. A vicious cycle
I don't even know where to start. One mechanic says its not my fuel pump or filter. My check engine light is not on, so I'm having a hard time finding someone around here with a good enough diagnostics to see if they can figure it out. I tried reading through past posts about idle problems and stuff, but had to search for all these abbreviations MAF ICS TPS... If anyone has had similar problems and would like to share their solutions (in words I may understand ) I'd appreciate it.
Thanks!
Old 11-12-2005, 02:10 AM
laser apexi turbo laser apexi turbo is offline
Re: 92 Laser starts/idles at 500rpm/stalls????
my turbo laser does this also, when i start it up sometimes it barely fires then dies. if i go to a stop light it will drop idle and die. I heard it could be a bent valve or 2. urs could just be a worse case scenario
Old 11-16-2005, 08:32 PM
Graham77 Graham77 is offline
Could be your Idle Air Control Module, or something more internal. Could even be your Throttle Body Positioning censor or the set screw could of backed off.
Old 11-17-2005, 06:46 PM
importaudihaus importaudihaus is offline
any cels?
Old 11-17-2005, 10:21 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
06-27-2005, 04:03 PM
I doubt he;s coming back.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
