Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 06-27-2005, 02:30 PM
BUFFS73 BUFFS73 is offline
Rear Door Ac Acculator
I Have Been Told By Local Dealer That This Part Is Not Working On My 2002 Explorer But I Was Not Told What This Part Does??
And Does Anyone Know How To Get To This Part?? It Is In The
Rear Of The Vehicle. That Is Where I Hear The Clicking Sound
Coming From.
Old 06-27-2005, 07:38 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Rear Door Ac Acculator
I think they were talking about the door lock motor. It is located inside the door panel. Remove the panel and have someone work the switch and see where the click is coming from.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 06-28-2005, 09:34 AM
Coming From.
NO I DON'T THINK SO. IT IS IN THE REAR AC UNIT SUPPOSEDLY???
MY UNDERSTANDING IS THAT THERE IS A DOOR PER SAY IN THE UNIT THAT DIRECTS THE AIR FLOW AND THIS DIRECTOR ?? IS CALLED THE ACCUATOR AND IT IS NOT WORKING. THIS IS WHAT CAUSES THE CLICKING SOUND.
Old 06-28-2005, 10:12 AM
way2old's Avatar
TOKEN HILLBILLY
OK. Sorry. I did not know we are talking about the A/C. It is probably the rear blend door motor. I do not think there is anything in there that directs air flow, but there is one that will control the temperature. Dealers will call a motor an actuator if it moves something by electrical current. Again there may be one for air flow. Haven't torn into one yet.
Old 06-28-2005, 10:43 AM
Re: Re: Rear Door Ac Acculator
Originally Posted by buffs73
No I Don't Think So. It Is In The Rear Ac Unit Supposedly???
My Understanding Is That There Is A Door Per Say In The Unit That Directs The Air Flow And This Director ?? Is Called The Accuator And It Is Not Working. This Is What Causes The Clicking Sound.
Yes That Is What It Is. Do You Know Where It Is And Do You Think It Will Be Difficult To Replace??? My Son Removed The Panel Covering From Inside The Car But He Said That There Is Like A Black Box There, Where The Clicking Sound Comes From.
Old 06-28-2005, 01:55 PM
way2old's Avatar
TOKEN HILLBILLY
The black box would be it. It probably sits on top of a rod that controls the door. Should be one or 2 screws that hold it on and it will lift off. When it is removed, be sure the door is not broken inside the unit. If door is broken or stuck, that may have led to the problem. There is an 8 way connector on the actuator, but only 4 wires going in it. They are Brown, White, Black and Gray with a Yellow trace color on it. Good luck.
Old 06-28-2005, 02:43 PM
Re: Re: Re: Rear Door Ac Acculator
THANK YOU SO MUCH WE WILL GIVE IT A TRY.
HAVE A GREAT DAY
Old 06-28-2005, 06:07 PM
way2old's Avatar
TOKEN HILLBILLY
Let us know the outcome of it. It may help another poster.
Old 06-29-2005, 01:54 AM
XLT03 XLT03 is offline
Had same problem on my 03. MInes was covered by warranty. Here's what the dealer did from what I gathered from the invoice. Got into the black box your son found. Discharged A/C (freon), removed black box to gain access to blend door. It was stuck. Replaced with new blend door. Reassemble and recharged A/C. Lots of hours. If you do it yourself you have to deal with freon R134a. Please post your results.
Old 06-29-2005, 08:22 AM
YES THIS SOUNDS CORRECT. THEY TOLD ME 3 HRS LABOR. AT 100 P/HR
CRAZY EH!!! MY HUSBAND AND SON ARE GOING TO GIVE IT A WHIRL
WORST THING IS THAT I STILL HAVE TO TAKE TO DEALER TO PUT BACK TOGETHER. I SUPPOSE???
