Old 06-27-2005, 12:20 PM
Stag Stag is offline
Question Droopy headliner
I have an '05 TB and the headliner over the driver's seat right near the sunroof has dropped a bit. I can stick my fingers into the gap and it feels like a piece of double sided tape has let loose. I have tried to reattach it and also use a new piece of double sided tape, but neither worked it still drops.
Any suggestions or recommendations as to what I could use or what would be a good fix?
Old 06-27-2005, 01:56 PM
gherb gherb is offline
Re: Droopy headliner
first thing i would check if there's a leak, even pinhole leak from the sunroof where moisture could get in and undo the effectiveness of the tape. but that's just my two bits.
Old 07-01-2005, 09:16 AM
Dry as a bone...checked it during and after a recent heavy storm.
Old 07-01-2005, 09:18 AM
BlulytesTB's Avatar
BlulytesTB BlulytesTB is offline
There is "industrial Velcro" in there... I just had the same thing, in the exact same spot fixed last week.
Next time you bring it in... have them fix it!
2004 Trailblazer LT
Old 07-05-2005, 01:01 PM
I will, thanks
Old 07-05-2005, 03:41 PM
FF_EMT37 FF_EMT37 is offline
Had the same thing happen to me after elss than a week of owning it. I just got it fixed at the dealer today.
Old 07-06-2005, 07:52 PM
emitchell233's Avatar
emitchell233 emitchell233 is offline
Send a message via AIM to emitchell233
Autozone also carries a spray-on adhesive specifically for headliners, might wanna try that.
2002 Trailblazer 4x4 LS 1SC
(4) BF Goodrich All Terrain TA KO LT255 70R16
1 piece stainless steel brush guard w/ (2) 100W 6" Summit off-road lights
Pioneer Head Unit and CD changer
K&N Filter with Chrome intake
Airraid Throttlebody Spacer
1.25" SuspensionMAXX front suspension spacers (1.75" total lift in front)
Flowmaster 50 Series SUV Performance Muffler
Mounted CB, PA and radar detector
www.BandOfMudders.com
Old 07-07-2005, 08:18 AM
If your vehicle is under warranty, I would strongly suggest you take it to the dealer. I had mine done the other day and the mechanic left the empty tube of adhesive in my truck. It was a GM labeled tube of gel adhesive. It looked very similar to Krazy Glue gel. So, if your truck is out of warranty, try using Krazy Glue. The spray-on adhesive is probably for the fabric and not for the entire headliner piece.
