Old 06-27-2005, 09:59 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Question Got Rims!... Bolts too short
Hey all
I finally got my rims. 4 Enkei (sp?) dark silver, 6 spoke, 18in rims with low profile tires yesterday. They're used, and I bought them off a friend, so I got them for $385. Tires are in great shape too. They came off a 3000gt show car! Ill post pics of them when they're on the car. Also have to be cleaned up a little.
Now when I tried to install them this morning, they fit perfectly. Only problem is, the bolts that come off the rotor that the lug nuts go onto, are now too short. The rim is actually an inch thicker that the stock 15in I got on now. Do they make entensions? Then, how do I install it? Where can I pick some up too? Im getting a brake job done in a few, so should I just wait until then? What to do? Thanks
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 06-27-2005, 10:03 AM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
Re: Got Rims!... Bolts too short
you can go to arp and get longer studs... only resolution i can think of....
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 06-27-2005, 03:43 PM
david-b's Avatar
Dave is THAT guy
How do I install them then? Do I have to take off the rotors? I think it'll be best just to get it done with the brakes all at once.
75 Monte Carlo
Old 06-27-2005, 08:55 PM
mindtwizzter mindtwizzter is offline
Send a message via AIM to mindtwizzter
u might wanna look into maybe tuner lug nuts cause my wheels are thicker than my studs but my lug nuts fit inside my wheel,look into it might save you some time and some $$....just go to a wheel shop and ask for tuner lugs and see if they work
Old 06-27-2005, 09:03 PM
drewh4386's Avatar
drewh4386 drewh4386 is offline
Send a message via AIM to drewh4386 Send a message via MSN to drewh4386 Send a message via Yahoo to drewh4386
Re: Re: Got Rims!... Bolts too short
yes you have to take off the rotors and drums. Getting it done with the brakes is a plus.
....It has been a LONG time...I want to move to FL or Japan.....
Old 06-28-2005, 11:24 AM
david-b's Avatar
Dave is THAT guy
Sothe tuner lug nuts are smaller? Ill have to see. Ill prob just get new bolts in when I get brakes done. Thanks guys
75 Monte Carlo
Old 06-28-2005, 04:26 PM
yes the tuner lugs fit inside the rim you would be better off with those or your gonna buy new bolts to put on there and they are gonna stick way out and look so fucked up,,,id try the tuner lugs before you go with the new bolts trust me
Old 06-28-2005, 04:49 PM
david-b's Avatar
Dave is THAT guy
HOw much we talking for something like this?
75 Monte Carlo
Old 06-28-2005, 05:52 PM
they are like 25.00 for the whole set you can get em at a rim shop...i promise its alot easier than changing all those old rusty bolts
Old 06-28-2005, 06:07 PM
drewh4386's Avatar
Ironicaly, I have a friend who went thru this same problem today. If you had any important plans today, I hope you didn't cancel them to put on some rims..........
In some cases tuner lugs are better the regular lugs. IMO
Old 06-28-2005, 08:29 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
I think everyone is assuming that the problem is with the stock lug nuts. Are they too thick to fit inside the wheel's lug recess? If so, new nuts are cheaper than longer studs. Otherwise, if you can purchase longer studs (i dont know because ive never heard of this problem), you will be able to buy new ones.
Old 06-29-2005, 03:42 PM
david-b's Avatar
Dave is THAT guy
Yeah, that is the problem. The rim is thicker than the stock rims, so the stud coming from the rotor is inside the new rim. The stock nuts wont fit in the hole on the new rim to reach to the studs. Everyone assumed right. Sorry.
I didn't have any plans. I just need to get these new wheels onm b.c. the old tires are shot to hell. No tread, uneven wear all around, and bald spots! Damn handbrake. lol
Ill try to find some nuts tomorrow. That came out wrong. Ill see what I can find. Ill probably have to take a rim with to see if they'll fit in the hole. Ill get back to ya all. Thanks
75 Monte Carlo
Old 06-29-2005, 04:26 PM
nickkalen nickkalen is offline
Ok you said that the rims were Enkei's? and the nuts dont fit inside the holes where the studs reside? Correct. Ive acturally had a set of rims from enkei that had the same problem, I never went with the tuner lugs though, but the problem was there was a special set of lugs that were shanked at the end so they would fit into the holes in the rim and grab more of the stock stud then regular lug nuts. Another problem that arose was that the lug nuts that were specially made for those were dicontinued because of stripping problems with the key. They had to be special ordered and set me back a good 100$ for just the lugs. Hoping thats not your problem you might want to look into it by getting the model number off the rims and calling Enkei Direct.
Old 06-29-2005, 04:46 PM
david-b's Avatar
Dave is THAT guy
Damn, that would definitly suck. I'll have to do some research on these bad-boys. I hope thats not the problem neither. Where did u special order them from?
75 Monte Carlo
Old 06-30-2005, 08:58 AM
You might want to try a few of these numbers. See what gets you the best results.
Location: 4900 Alliance Gateway Freeway, Fort Worth, Texas 76177 U.S.A.
Phone: 1-817-490-5600
Foundation July 1, 1984
Operation Sales of Enkei-brand production.
Enkei America Inc.
Location: 2900 West Inwood Drive Columbus, Indiana 47201 U.S.A.
Phone: 1-812-373-7000
Foundation September 30, 1985
Operation Manufacturing and sales of aluminum wheels for automobiles.
Enkei Florida Inc.
Location: 1401 Wheels Road Jacksonville, Florida 32218 U.S.A.
Phone: 1-904-741-1991
Foundation October 10, 1997
