Old 06-27-2005, 09:24 AM
bigdinz's Avatar
bigdinz bigdinz is offline
Radiator Question!
I'm in need of a new radiator and the on-line stores ask if I want one with/without an oil cooler. I didn't notice my current one having that. Do I need it or not?
Thanks
Old 06-27-2005, 11:33 AM
Tangent Tangent is offline
Re: Radiator Question!
Just check your current radiator for more fittings. If yours has the transmission oil cooler you'll find a couple of metal lines going into it. (Probably near the bottom) If you don't have it the only thing going into the radiator will be the 2 coolant hoses.
Old 06-27-2005, 12:08 PM
blazee's Avatar
blazee blazee is offline
Problem?
If you are refering to your 98 blazer, you need one with the oil cooler. Yours has an oil cooler and and tranny cooler.
Old 06-27-2005, 07:04 PM
bigdinz's Avatar
I appreciate it!! I do remember seeing metal lines coming from the bottom. Guess that's the oil cooler parts of it!
Thanks Again!
Old 06-28-2005, 04:28 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
How do you know you need a new rad?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 06-28-2005, 06:07 PM
bigdinz's Avatar
I had been smelling fluid for a while. I investigated and found fluid all over the driver side. It was leaking from near the top on the plastic part,small cracks in the plastic. I tried to seal the cracks with some sealer(epoxy). This didn't work and actually made the leak worse. I haven't looked to see where it is coming from now but it is definitely wore than before. New water pump.
Old 06-28-2005, 07:50 PM
BlazerLT's Avatar
AF -Advisor
Makes sense.
