Old 06-27-2005, 08:55 AM
craigyd71 craigyd71 is offline
87 Accord starting problem
Hey guys,
I have an 87 Accord that when I turn the key sometimes the car turns right over as if it was brand new and other times I have to turn the key 14 times to get the starter to turn. When I'm having this problem I can hear the starter click for just a second. Any ideas what this might be?
Thanks
Craig
Old 06-27-2005, 10:16 AM
mpumas mpumas is offline
Re: 87 Accord starting problem
Could be a bad segment on the armature. If you don't do something about it, you will eventually find that jogging it won't work. Recommend changing the starter.
Old 06-27-2005, 11:43 AM
AccordCodger AccordCodger is offline
COuld also be a bad starter relay.
Old 06-27-2005, 05:24 PM
Deadhead's Avatar
Deadhead Deadhead is offline
have you thought about your battery cables? that would also cause the problem.
I had the same thing happen with my 86, replaced the cables, and it had a better connection, therefore had enough power to turn the starter.
With the old cables, i was able to do everything but start it. How corroded are they?
1986 Honda Accord LX-i 5 spd
Completely stock... but i like it anyway, it's got a strong e-brake
www.cheesemit.us
http://www.cardomain.com/ride/862348/1
