Go Back   Automotive Forums Car Chat > Ford > Contour
Old 06-27-2005, 08:47 AM
kathy059 kathy059 is offline
Question Brake light problem
I have a 1996 Contour. My two main brake lights aren't working, the third light works fine. I've changed the bulbs and the fuse. My signal and hazard lights work, its just the brake lights that won't come on.
Any help or suggestions out there before I get pulled over?
Old 09-14-2005, 09:25 AM
mcervarich mcervarich is offline
Kathy,
Did you ever get an answer? I have the exact same issue. Checked bulbs, fuses looked at wiring diagrams and no luck yet.
Old 09-14-2005, 11:07 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Searching contour.org is your friend.
Sounds like you need a new MFS. Click the link for discussion and replacement. Theres a step by step diagram from autozone thats posted in that link as well.
http://www.contour.org/ubbthreads/sh...ue#Post1049207
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 09-14-2005, 05:32 PM
Re: Brake light problem
contour.org is indeed my friend. . .although it wasn't the multifunction switch. The last post in the thread and another similar one both replaced MF switches only to find the B pin in the connector was charred (New MF switch not needed). Just finished taking off my MF switch and sure enough, B connection. Brakes lights are working now.
