Old 06-27-2005, 08:30 AM
rla143 rla143 is offline
Starter or alternater
im still waiting to see if i can get a response for the reverse lights but anyway i have a problem in the first start of the day car cranks slowly it requires 2 turns but it struggles but then it starts after that starting is ok what could it be?
Old 06-27-2005, 04:40 PM
B33p3r B33p3r is offline
I also posted to your reverse light issue, then I saw this. It appears to me something is putting a slow drain on your battery. Overnight it drains down low, but not enough time during daylight driving to allow battery to drain down. Hmmm.....Reverse lights or neutral switch you replace draining battery. Minor short somewhere? You can monitor drain on the battery while removing fuses 1 at a time to see which one eliminates the drain. I'd start with the fuses for the other circuits you're having problems with.
