Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 06-27-2005, 12:13 AM
mlw35405 mlw35405 is offline
Question 2000 SPI Auto Transmission Problems
I have a 2000 Focus SPI with the auto transmission and around 165K miles. Recently, the transmission will not shift out of first gear until around 5000 rpm OCCASIONALLY. Most of the time its fine. When it's acting up, it won't even shift into second gear even if I move the shifter into 2 (which should lock the tranny into second and make it stay there). And then there are times (when its in this bad mood) when I push the pedal to the floor going about 25 mph and it doesn't want to downshift out of 2nd once it finally gets into it.
SO what I was wondering is if anyone knows if I have a sensor problem (No check engine light is on), maybe a bad solenoid, or what?? It's aggrivating, because it doesn't do it all the time, usually only in heavy stop and go traffic, so I want to believe it's not a hard fault in the tranny.
ANY HELP OR SUGGESTIONS WOULD GREATLY BE APPRECIATED!!!
The young and the young at heart wait,
But the wait never ends in the soul,
When you feel like its all blown away,
Independence has come,
And into the night I go...
Old 06-27-2005, 12:39 AM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: 2000 SPI Auto Transmission Problems
sounds like a speed sensor to me, has your O/D light even came on and flashed?
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 06-27-2005, 06:55 AM
Nope, and there is a test you can do to make the trip odometer display your speed, and this shows that the speedo sensor is fine. I figured out that when the car is acting up, you can shift into neutral and turn the switch off and then back on and it'll shift fine, which only makes me more confused!
Old 06-27-2005, 12:59 PM
pre98zetec's Avatar
speed censor doesn't measure the speed of your vehicle, it tells the tranny when to shift according to the speed you're at.
-Josh-
