Old 06-26-2005, 11:29 PM
lckycharm713's Avatar
lckycharm713 lckycharm713 is offline
30 over bore on 350
hey guys. i have a 350 block bored over 30. the pistons are marked 20. is this right? if its bored 30 over , shouldnt the pistons be marked 30 as well. i know you cant take something the same size and put it together, but dont they messure for this when they do the bore (i heard the stock block bore is a little bigger). i think a piston marked 20 over is for a 20 over bore. or marked 30 for a 30 over bore. im not sure how this works. i know the rings set good, but i want to make sure before i go cranking everything down. please help
2000 Mustang - just a V6 with lots of good looks
1974 Camaro - 350 4bolt main .30 over, turbo 350 trans w/ shift kit.
1999 F-150 Lariat 4x4 5.4L
"Only babies suck bottles (NOS)"
Old 06-26-2005, 11:45 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: 30 over bore on 350
with a 4.030" bore, you want to have 4.030" pistons.
Old 06-27-2005, 08:33 AM
so what i have is wrong
Old 06-28-2005, 04:17 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
my guess is yes. but you could always bust out the micrometer and check you can order .020 oversized pistons, so i think thats what you have. you will need .030 over sized pistons.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 06-28-2005, 06:44 PM
we put a piston in the block without the rings on. and it set in place nice and snug. this was b4 i i found this out, i was not thiking, but no lets say if the bore was 30 over, wouldnt a 20 over piston fall right out? (no rings on piston yet)
Old 06-29-2005, 02:01 PM
89IROC&RS's Avatar
youre talking about a hundredth of an inch, not exactly sloppy loose fitting. I really dont think the piston would just fall out. but what you can do to check is to use a feeler gauge to check the clearance between the piston and the bore, im not exactly sure what its supposed to be, but you could email someone at JE pistons or a similar company and check that out.
Old 06-29-2005, 03:00 PM
its going to have to come down to that. i know the piston is supposed to be .003 -.005 of and inch smaller. the problem on this is that i have the heads all bolted down and my friend is getting pissed that i am questioning him on it, hes one of these guys that thinks hes the best motor guy out there. i know if i rip it apart, he will tell me to stick this project up my ass. then im screwed.
Old 06-29-2005, 03:20 PM
89IROC&RS's Avatar
well your friend sounds like a punk, tell him if hes willing to help you pull, tear down, re-assemble, and re-install the engine, because you have excessive oil consumption due to undersized pistons, youll go ahead and not question him on it. OR he could stop being a dumbass and pull a head to check piston to bore clearance, it will take what, a half hour to do that. geeze, go buy him a sewing kit for his bleeding vagina.
Old 06-29-2005, 06:20 PM
black84z28 black84z28 is offline
you need a 0.030 over sized piston...no ands ifs or butts about it
Old 06-29-2005, 06:35 PM
Robs71Nova's Avatar
Robs71Nova Robs71Nova is offline
Send a message via AIM to Robs71Nova Send a message via Yahoo to Robs71Nova
Yes, it is probably wrong....
Most of the time a "good" machine shop will not even bore a block out until they have the pistons you are going to be using in the motor, just so they can make sure everything is done perfectly.
Rob
Old 06-29-2005, 06:45 PM
Re: Re: 30 over bore on 350
you couldnt have said it any better my friend.
