Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 06-26-2005, 10:18 PM
SenseiAccord SenseiAccord is offline
Best High Pressure Assembly Lube
Does anyone know which brand of High pressure assembly lube or cam lube is best? i wanna install my cam in my car already but i need some high pressure cam lube to make this work. anybody know which stuff is good? thanks!
Old 06-27-2005, 12:58 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Best High Pressure Assembly Lube
any high - extreme pressure assembly lube will do. sta-lube w/ moly graphite is what i use. its only essential for the first few initial start ups. just go pick up any brand from your local autoparts store. as long as its high - extreme pressure assembly lube, you will be fine.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 06-27-2005, 01:31 AM
Re: Re: Best High Pressure Assembly Lube
thats sounds good then. i guess cams dont really require that much shiet since it aint under that high of stress or metal to metal contact like main bearings or something. thanks man!
