Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 06-26-2005, 08:46 PM
slammedcavi254 slammedcavi254 is offline
Unhappy does anyone know what this is??
i found this in the trunk of my 99 cvpi i was wondering what it is?? i have no clue. any help would be appreiciated
[IMG][/IMG]
[IMG][/IMG]
Old 06-27-2005, 03:17 PM
cobradude360's Avatar
cobradude360 cobradude360 is offline
Send a message via AIM to cobradude360
weres it located
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that
MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs
also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon
Old 06-28-2005, 07:53 AM
Unhappy
it on the drivers side of the trunk, any other cvpi have this????
Old 06-28-2005, 08:42 AM
jimmytroanoke jimmytroanoke is offline
Re: does anyone know what this is??
Is there a reset button on it somewhere. My fuel pump inertia switch is on the side of my trunk in my 95 GM
2001 Grand Prix SE 3.1 - Someone elses problem now!
95 Grand Marquis - Will outlive all of them!
97 F-150
2004 Toyota Avalon
Old 06-28-2005, 05:32 PM
RouterDude RouterDude is offline
I cant tell exactly where that is in the car, but it looks like it is directly behind the back seat. On all cars the wiring harness will be complete for all options, so it doesnt matter if it is a PI or not. The only exception to this is the PI model, they have the additional wiring for the lights that the common cars do not. Depending on the model and options of the car, they can be for either an amplifier, a subwoofer or, in some cases, the actual radio. Some cars the radio is in the trunk and the head unit in the dash only acts as the control center and tape player, the actual tuning and amplification is in the trunk. On the drivers side, those might be the power and signal wires for the subwoofer which is mounted to the left of the spare tire slightly ahead and to the right of the left rear speaker. if you look up there you should see the hole where it would mount.
Old 06-28-2005, 08:26 PM
its def. not a radio acc. wire, it has constant power going to it. i can follow the wires into a harness to the front. it is located in the trunk, on the drivers side, under of the carpet near the fuel cutoff switch. does anyone know if this can be a rear flasher??? thanx!
p.s. ther is NO reset button anywhere!
Old 06-30-2005, 03:45 PM
radioman2002 radioman2002 is offline
If it looks like the old computer connection EECVII found under the hood. It probably is the diagnostic connector for troubleshooting the air ride suspension. Comes on all the cars I've owned, whether it had air ride or not.
Old 07-04-2005, 10:36 AM
it is not a connection for an ecu. it is two solenoids with wires coming out of it, some kind of harnes....
Old 07-08-2005, 07:28 PM
Well then it might be a tow harness kit for the rear lights. I had them on 3 of my 1996 CVPI, for the rear deck lights. Don't know if they still do it in 1999, but since the brake lights go through the LCM, I would hope they still isolate them with realys.
