Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 06-26-2005, 08:03 PM
monooxide's Avatar
monooxide monooxide is offline
Banned
Send a message via AIM to monooxide Send a message via MSN to monooxide
Turbo KA Power...
I want to see what kind of HP range were looking at...
Stock Internals
5-6PSI
200-225
7-11PSI
230-265
12-16PSI
270-300
17-25PSI
310-350
26-31PSI
370-435
Old 06-26-2005, 09:02 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Re: Turbo KA Power...
Is this a question or what you have figured? Because those numbers are off. There is no set power level for a set PSI. Airflow is different at set pressures from compressor to compressor.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 06-26-2005, 09:29 PM
240SXSlideStar's Avatar
240SXSlideStar 240SXSlideStar is offline
And is that whp or chp?
-Jonathan
JDM Racing Motors inc
Montreal, Canada
www.jdmracingmotors.com
Old 06-26-2005, 10:05 PM
monooxide's Avatar
Banned
Hmm..
Those are just all guesses. I dont want definites i just want peoples numbers like NissanFanatic got from 5-6 PSI and then at 9PSI what he got or TatII what he got at his Boost levels. I just want a general range at what ill be looking at to get close to my friends RB25 Swapped 240 hell be getting it done in the beginning to mid August.
Old 06-27-2005, 12:06 AM
Hit_N_Run-player Hit_N_Run-player is offline
Send a message via AIM to Hit_N_Run-player
there are too many different variables that will detirmine the HP rating at a given PSI....you need a more defined question.
1988 conquest TSI
-Lots of mods, finally finished WOOT!!
Horsepower sells cars,
Torque wins races!
Old 06-27-2005, 12:25 AM
240SX Guy
Then get a generic idea of what turbo you will be running...
-Cory
12.6@122mph
Old 06-27-2005, 12:45 AM
TatII TatII is offline
15 psi can range anywhere from 280-350whp depending on turbo, and supporthing mods. if everything goes well i'll dyno this week and see how much power i'm making at 14.5 psi. ( i'm guessing 300whp ) but anthony made 345whp from 15 psi.
303whp stock internal KA-T
94 Acura NSX
Best E.T. 13.559
Best Trap speed 107.62 mph
Old 06-27-2005, 12:58 AM
LaYzIeNoY LaYzIeNoY is offline
Send a message via AIM to LaYzIeNoY
you can't ask based on psi alone you need to list you supporting mods and turbo, you'll probably get the best info from the ka-t guys here, ka-t.org might help don't know personally though
7psi on a T25 is going to be alot different from 7psi on like a T88, its the difference in flow of the turbo
and someone correct me if i'm wrong but i don't think that the stock internals will hold up to good past like somewherin 15-20psi range
Old 06-27-2005, 01:01 AM
usually with good fuel management, the stock internals can handle 350whp pretty decent. whatever psi that is, it depends on the turbo.
94 Acura NSX
Best E.T. 13.559
Old 06-27-2005, 01:22 AM
240SX Guy
Power=airflow. Plain and simple.
-Cory
12.6@122mph
Old 06-27-2005, 01:31 AM
monooxide's Avatar
Banned
supposively
They have held up to 450...I believe...
and lets say...
Stock Internals
GT28R DualBB
Turbine
-Wheel: 53mm w/ 62 trim
-Housing: .64 ar
Compressor
-Wheel: 60mm w/ 60 trim
-Housing: .60 ar
JWT or Enthalpy
550cc Injectors
255L Fuel Pump
Small FMIC
5-6 PSI and then 12PSI...
Old 06-27-2005, 02:31 AM
240SX Guy
They have held 404whp documented.
5-6psi, prolly about 220-230whp
12psi, prolly 320-330whp
GT series turbos are very efficienct making more power at lower boost.
-Cory
12.6@122mph
