Old 06-26-2005, 07:29 PM
angels7113 angels7113 is offline
Rough starts
My car usually wont start on the first turn unless you hold it for a second and it's real jumpy and idles a 2100 until the car warms up. The motor is also very noisy and pingy.
Old 06-27-2005, 10:03 PM
1989_cash_eater's Avatar
1989_cash_eater 1989_cash_eater is offline
Unhappy hard to start?
I seemed to have the same trouble latey. I found that after I replaced the plugs, which happened to be covered in oil, it start much easier, and idles a little better. I'm no expert by any means but i'd say that you should check the plugs/wires/distributor cap, fuel lines for leaks, idle and intake. I'm after replacing just about everything with no luck accept for the plugs which made the most difference.
"If you can read this...I'm Parked!..............Or broke down."
Old 06-27-2005, 10:07 PM
Re: Rough starts
What would be good plug and wires, and a distributor is just a distributor right.
Old 06-27-2005, 10:13 PM
Re: Rough starts
another thing is i'm pretty sure it started rough before the swap so i don't think it would be the motor
Old 06-27-2005, 11:06 PM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
Re: Rough starts
If the motor is noisy and pingy - you may have some valves that need to be adjusted - they are usually somewhat noisier when it's cold just because it's cold, but might want to have them looked at.
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
