Old 06-26-2005, 07:19 PM
kita23 kita23 is offline
intake?
here is a link
http://cgi.ebay.com/ebaymotors/ws/eB...category=38634
Is it worth getting? I am kind of really tight on money right now so this is really all i can afford for the time being. Weigh In on all opinions please.
Old 06-26-2005, 07:38 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Re: intake?
Originally Posted by kita23
here is a link
This always starts a fight. I don't like them at all. You draw the hot air from the engine. Grand Prixs run best on cold air. CAI (cold air box) or FWI (fender well) are the best.
Good luck
Old 06-26-2005, 08:28 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Re: intake?
Good luck
I agree with Jim. Advertisement is misleading & deceptive. Save your money up and get something that really works.
"Adds up to 10 to 15 additional horsepower and up to 16 foot pounds of torque !" ( result might be vary )
If you remove the stock airbox where do you plan on mounting the ECU/PCM and it didn't address whether there was a fitting for the IAT sensor?
Thrasher CAI, DHP v1.0 PCM,
3.25 SC pulley, CAIT GMAF, Hi-Flow CAT,
u-bend delete, 160 TS, TB spacer,
MSD 8.5mm wires, Autolite 104 Spark Plugs,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
Timeslip 08/12/06
AF Community Guidelines
Old 06-26-2005, 09:03 PM
Re: Re: Re: intake?
Bob,
I didn't want to raise the flag on this, but.........
Old 06-26-2005, 10:50 PM
Ripn12s's Avatar
Ripn12s Ripn12s is offline
Send a message via AIM to Ripn12s
Re: intake?
If your tight on money i wouldnt waste any on a intake when all you need to do is take a saw to your stock airbox and gut it.
Old 06-27-2005, 11:36 AM
theblurr87 theblurr87 is offline
Send a message via AIM to theblurr87
Re: intake?
here is a link
looks like they're getting you with shipping as well. if money's tight a homemade FWI or plain open cone filter with parts from home depot will do just fine otherwise gutting stock airbox will do like ripn said.
those numbers are def. BS tho..
'99 SE (l36) 125k mi.
FWI | ZZP HVTB St. 1 | WP UD Pulley | 3" DP/HF Cat/U-bend Del.
Old 06-27-2005, 07:31 PM
jeffs_GTP_sleeper's Avatar
jeffs_GTP_sleeper jeffs_GTP_sleeper is offline
Re: Re: Re: Re: intake?
Yeah if you are trying to be economic with your mods, I would just buy a cone filter and build your own intake.
At the track with the headlight out open cone is fine, but in heat and city driving a FWI/CAI is going to keep the temps down much better.
Old 06-28-2005, 09:57 AM
intake
Well I am going to build my own open cone steup. My only question is I have a 1997 and the coolant bottle is right behind the driver's headlight. Now i know the PCM has to be relocated, so where do i tie it to? Where the air box used to sit? What do i tie it to? With the coolant bottle there will there be enough room? Anyone got pictures? B/c i really dont want to have o move to coolant bottle. Thank in advance.
Old 06-28-2005, 10:18 AM
BNaylor's Avatar
Re: intake
You'll have to figure out whats suitable for your given situation which includes re-mounting or properly securing the ECU/PCM.
On the coolant recovery bottle when you install a Thrasher CAI the coolant recovery bottle is in the way. So you have to get one for a 1999 GP and up and then mount it to the passenger side strut tower. You may have to do the same.
Timeslip 08/12/06
Old 07-05-2005, 04:38 PM
leadfootGTP's Avatar
leadfootGTP leadfootGTP is offline
Re: intake?
you can buy pcm trays if you're having trouble mounting it
http://www.3800performance.com/Merch...roduct_Count=5
[IMG][/IMG]
Old 07-05-2005, 05:43 PM
Re: Re: intake
Only good if you have the 99 and up coolant bottle which i dont.
