Old 06-26-2005, 06:51 PM
MaxBURNOUT MaxBURNOUT is offline
Send a message via AIM to MaxBURNOUT
B16 or B18 that is the question
I have a Si but the idiot that I got it from droped a D15B2 in it, (Dot ask me why) Im looking to get it to a SiR or better. Im looking at the cost, how difficult it is to install, and all the parts that im going to need. If you have any suggestion on what you think that I sould do let me know. I know that in the end it is my pocket book, and my car. but I really need some suggestions ... Im thinking of doing it peice by peice but I dont know what to start with. Head, cams.. ect. you know the drill.
Thanks Guys
J
Old 06-27-2005, 04:33 PM
SiZ's Avatar
SiZ SiZ is offline
Re: B16 or B18 that is the question
Start with the search button, there's hours of debate about this kinda stuff.. And most of us are too lazy to get into it anymore.
Old 06-27-2005, 04:48 PM
ahhh
thanks
Old 06-27-2005, 04:57 PM
iVteC_PoWeR iVteC_PoWeR is offline
Send a message via AIM to iVteC_PoWeR
why not just go with a gsr? A lot better IMO because of the torque so just keep the D15 for now and save up for the B18c. Trust me you will love torque.
Old 06-28-2005, 04:44 PM
Well, Eather way im going to keep the D15 until I get another engine. and fix it up. while its out of the car.. besides if I go with the B18C... what else am I going to need get when I do the swap...
Old 06-28-2005, 05:01 PM
Should I go with the B18C? ...345
Old 06-28-2005, 07:05 PM
YES you should go with the GSR! And you need the motor mount kit to install it.
Old 06-28-2005, 07:27 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
ECU, transmission (tranny mount conversion if you get a hydro tranny), axles, shiftlinkage.
Old 06-28-2005, 11:23 PM
So a B18C5... I should go for that.. Would it be possible to build the engine peace by peace? and where do you think I should go for the parts... or should I look for a used.. I looked for one one the web,, but there was one like 300 miles away..
Old 06-29-2005, 12:05 AM
CivicSpoon's Avatar
There is no Spoon
If you go with the ITR engine, you should buy all the parts at once. There are quite a few good places online to buy them from.
Old 06-29-2005, 12:50 AM
Exempt Exempt is offline
Send a message via AIM to Exempt Send a message via Yahoo to Exempt
Depends on what you wanna do...
N/A then C5 all the way!
If you wanna boost it, go with the C1...
The C5 has higher compression and not so well for boost...
I personally would go with the B18C1 GSR engine...
Old 06-29-2005, 01:14 AM
So your saying that the c5 has more HP but the C1 has more torque?
Old 06-29-2005, 01:30 AM
Re: Re: B16 or B18 that is the question
No...
B18C5 195HP @ 8000 rpm 130 lb/ft @ 7500 rpm
B18C1 170HP @ 7600 rpm 128 lb/ft @ 6200 rpm
(those are US Specs)
What Im saying is, for a naturally aspirated, the C5 is definately much better... They are high revving engines, made to be taken to high RPMs... They also have a slightly higher compression ratio (and much higher on the JDM versions)... This is good for a N/A setup...
The C1 however, is good for turbo or super charging... Which is what most Honda people want to do... And with the slight difference in HP, a boosted C1, can net more HP and torque, than your average N/A C5...
Old 06-29-2005, 01:54 AM
Well then im going to go with the C1... Im just getting frustrated,,, I can buy the whole engine for like 3500 but I dont want to just save and do that. I would rather, buy it peice at a time and build it my self.. I know im weard. I just like to know that my hand turned every nut and bolt. the only thing is.. I have no idea how to start looking for the parts or even where to look. that is my issue. I would like to get for example.. head. then maby the crank shaft.,,, any suggestions
Old 06-29-2005, 08:50 AM
What year model engine am I looking for.?
I dont want to get parts for the wrong engine, I know its the 1.8L B18C1. but they made them all the way to 2000 I think.
