Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 06-26-2005, 06:03 PM
zerocrxsi zerocrxsi is offline
Question high rpm idle
i just bought a crx w/b18(ls) and it ildes at 3-4k rpm and was wondering how do i lower it down if it is possible my friend told me there a screw or something on the head that controls it but not sure
Old 06-26-2005, 06:26 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: high rpm idle
That pretty up there in the rpms. But yes there is a screw, it's on your throttle body.
Old 06-28-2005, 01:27 AM
HontegraGSI HontegraGSI is offline
Re: high rpm idle
I have the same problem, but mine idles at less than 1k rpm. will this "screw" solve my problem too? does it affect the way it runs?? And where is this screw located at? please help me and zerocrx out...
95 Integra GSR (4 sale)
89 CRX Si B16a (Sold)
98 Civic eK
Old 06-28-2005, 02:06 AM
CivicSpoon's Avatar
There is no Spoon
Re: high rpm idle
http://img.photobucket.com/albums/v4...628-024926.jpg
Old 06-28-2005, 04:33 PM
Severity Severity is offline
the ls should idle at 750 rpms. that is normal. does the crx idle at 3k when the throttle cable is disconnected? the screw usually isn't meant to be used, unless someone else was messing with it. you might need a new throttle body. try a junk yard.
Old 06-28-2005, 07:47 PM
Re: high rpm idle
messed around with the screw n it idles 1-2k so i guess it helped is it still to much?
Old 06-28-2005, 08:25 PM
CivicSpoon's Avatar
There is no Spoon
Re: high rpm idle
You're not throwing any check engine light codes are you?
Old 06-28-2005, 09:04 PM
Re: Re: high rpm idle
not at start but wen i drive it for a while one does come up
Old 06-28-2005, 09:51 PM
CivicSpoon's Avatar
There is no Spoon
Re: high rpm idle
You should pull the code, it might be related to the high idle (even though it comes on when you're driving).
Old 06-29-2005, 07:28 PM
integra1998 integra1998 is offline
i have a similar thing happen to my car (98 Teg GS Auto ) .... when i first start the car it goes up to 2K then slowly going down to one. after 5 minutes or so. ... then once at one.. if i stop at a red light or something it will almost go down to zero then back up to 1... it just keeps on doing that. It bothers the hell outta me please help. No check engine light comes on or anything.
Old 06-29-2005, 08:20 PM
i need a new throttle body.....any b series will fit? its a 91 ls teg
Old 06-30-2005, 02:58 AM
Medabots Medabots is offline
Re: high rpm idle
I feel good now that I know Im not the only one wiht that problem. I change the Intake manifold on my LS and I think the throttle body got fucked up. When I turn the car on it idles up to 3k or something, and stay there. even when the throttle cable is not conected. do you guys think is the screw? I heard somenthing involving the vacum line on top of the manifold.
nice question, I was about of posting a thread but you guys are allready helping out.
Still trying to get a GOOD price in a LS transmission...
Old 06-30-2005, 03:22 PM
check all your lines it shouldnt be the screw if someone hasnt messed with it you probably have the same problem i do you need a new throttle body
Old 07-01-2005, 01:58 AM
Re: high rpm idle
I just solve my problem today, I took it to some friend and he found the answer. When I installed the new manifold I used the new gasket for the TB that came wiht it. the gasket did not have the holes for the sensors and that was one of the reasons. Then we thight the manifold a little bit more adn PUF!! the problem stop.
The manifold was sucking air from one of the sides and that caused the Idle. I took it for a ride today, men that new manifold and fuel rail make a difference. sounds better, runs better and I got it for cheap.
before changing your Throttle body I suguest you look for every little thing that can come to your head, some times the problem is so simple that you do not bother thinking about it.
Old 07-12-2005, 05:27 PM
Smoghog Smoghog is offline
Hey, Just wanted to add some info on IAC's (Idle air control valves)
These stick open and will cause high idle conditions and most of them can be cleaned out with a little carb cleaner. So if your idle will not stay
put then....
Smoghog out with a 88si
