Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 06-26-2005, 05:44 PM
tsi9187 tsi9187 is offline
Bov
On a stock bov i noticed that when i take the pipe that puts the air back into the turbo off it makes an aftermarket bov sound. does this harm the engine or turbo.
Old 06-26-2005, 06:10 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: Bov
yes, yes it does
put it back
now - 2000 civic
soon - 2002 is300
Old 06-26-2005, 06:25 PM
Re: Re: Bov
alright thank you
Old 06-26-2005, 07:35 PM
clipsekid99's Avatar
clipsekid99 clipsekid99 is offline
Send a message via AIM to clipsekid99 Send a message via MSN to clipsekid99
If you want to vent your BOV, or in other words, what you were just doing by taking the recirculation pipe off, you need the proper setup to do it right. You would need a MAFt, and a blow-through uicp pipe and intake pipe. Some people call this a ricer mod cause it doesn't really help you unless you have a certain amount of air flow (huge turbo). You can find more info if you do a little search.
2006 Wicked White Evo IX GSR
323 awhp / 311 tq. (Dynojet)
http://www.projectevoix.com
http://www.4WStuning.com
99 RS < 98 GSX < 06 EVO
Old 06-26-2005, 10:32 PM
Re: Bov
thas cool i was jus messin around with it one day and it did that but i didnt know if it hurt my car or not so i just put it on and finally got around to askin you guys. thx tho!!
Old 06-27-2005, 07:42 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Bov
It's not like your car will blow up if you vent the BOV. It will start to mess with the idle and you will run rich between every shift.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 06-27-2005, 07:20 PM
Re: Re: Bov
i did notice that the idle dropped down but i also noticed that when i kink the hose the the intake it didnt do it that bad so i was just seein if you could cork the hose and it wouldnt do that but i dont think you can
Old 06-30-2005, 01:17 PM
viet_boiiiii's Avatar
viet_boiiiii viet_boiiiii is offline
Send a message via AIM to viet_boiiiii
Re: Bov
I've been having my HKS vented for a month or 2 now and its getting better and better. It used to shift wierdly and now its normal. I dont know why it does this but the first month i had it vented, it sucked. Second month i noticed it drive normal now even though i cant actually see the real problem.
new 2006 Scion tC - 5spd
-magnaflow catback
http://www.cardomain.com/ride/2088489
~~~R.I.P (7-2-05)~~~
1998 Eclipse Gst - 5 spd
Old 06-30-2005, 06:08 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
Re: Re: Bov
Is that an example of the ECU "learning" a new driving mode or something? Like how they say the computer "adapts" to the driver?
The daily driver. The weekend cruiser. The lazy shop hog.
Old 06-30-2005, 07:58 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: Bov
Must be, but I'm still glad there isn't a cheap ECU hack to be able to vent without 'noticing' it. Just because you think everything is alright doesn't mean it is.
Old 07-01-2005, 10:44 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Bov
The ECUs only learning is in trims, which will adjust with about 10 minutes of idling, and 10 minutes of steady state cruise, for the most part. There is nothing that will take a month to learn. More than likely the driver just learned to drive around the problem. After years of running a vented BOV on stock MAS I was able to make it work with my driving style changes. Once I went to the MAFt and it ran much better, it took a long time to unlearn those crazy driving habits.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
