Old 06-26-2005, 04:49 PM
irupp33's Avatar
irupp33 irupp33 is offline
Send a message via AIM to irupp33
Alternator or some other problem?
Ok i was driving today just to stretch the cars legs a bit and on my way home when i would hit about 10 psi it feels like my car hits a wall. Now i had this problem before and it was broken stock plug wires arcing out so i switched to the nology hotwires and it was fine but thats exactly what it feel like. I get home and my electronics start acting up, radio glitching, radar dector going nuts, etc... and then the car stutters a few times and dies. I go to start it and nothing just click click click... Does this sound like a bad alternator or something else? Also even when the car is on the headlights come up extremly slow. And would a bad alternator make your car runs like shit while driving?
1991 Eclipse GS-T
Exterior: stock
Interior: Boost and A/F gauge, TV/DVD player, thats about it.
Motor: supra side mount, hard pipes, greddy type s, greddy profec b b/c, nology hotwires, 3 in. turbo back exhaust.
Wheels and tires: stock shitty fan rims with stock tires (no grip what so ever)
Old 06-26-2005, 05:21 PM
snake_canyon snake_canyon is offline
Re: Alternator or some other problem?
to diagnose alt. take the battery down to oreillys, have them check the battery first. in the process they will charge it for you. if the battery is good take it home and put it in the car. if you have a multimeter then start the car and check the voltage accross the battery, if the alt is good voltage will come up at 14+ volts. also make sure that the car is idling at a fair speed, i like to go about 1200 rpm just to make sure the alt is spinning fast enough. if the alt is bad then the voltage will read below 13volts. has been a good way to check for me so far.
also stuff acting stupid (radio, lights, etc.) check and make sure that all of your fuses under the dash are tight. i had the same problem with things turning on and off randomly and all i had to do was bend the blades a little to give them a tight contact.
good luck. let me know if you need help with the easiest way to change an alt.
Old 06-26-2005, 05:23 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
yes, that sounds like an electrical problem. your alternator quit charging the system so your car was running off the battery and the battery can only go for so long and then it shut everything down.
95 Talon TSI AWD
97 Eclipse GST
Old 06-26-2005, 05:45 PM
irupp33's Avatar
Ok but would it also make it run like crap while the motor is under more of a demand like at higher boost levels?
1991 Eclipse GS-T
Exterior: stock
Old 06-26-2005, 05:53 PM
yeah
95 Talon TSI AWD
97 Eclipse GST
Old 06-26-2005, 06:51 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
OH YEAH... when the engine is under more of a load it does use more juice... My guess would be the alternator.... another way of telling if it's the ALT... while the car is idling, disconnect the battery... if the alt is doing it's job it should keep the car running... if not it is, or is going bad... I agree also with having a load test done on your battery also... might be a combination of both the battery and ALT
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
