Old 06-26-2005, 03:02 PM
79403ta 79403ta is offline
day time running lights
i have two questions first off is there a way to turn off the Day time running lights without cutting wires etc.. ( can i just pull a fuse) ?? and is there anyway to clean the headlight lenses w/o buying new ones thanks
Old 06-26-2005, 08:04 PM
LT14x4 LT14x4 is offline
yes there is a fuse you can pull for the daytime running lights.The green
light will still be on but the headlamps wont.to restore the clearness of
the headlight lens you will need:1500 grit sand paper,some water,some
rubbing compund,and a buffer
1.use the sand paper with water and sand headlight lens until yellow film
is removed.
2.use rubbing compound with buffer to smooth the sanded surfaces.
and if your still not satified repeat steps 1 and 2 until you get good
results
