Go Back   Automotive Forums Car Chat > Buick > Skylark
Old 06-26-2005, 01:53 PM
michigander2005 michigander2005 is offline
Cant push car in neutral
Appears I have auto tranny problems ,, what would lock it up so it cant be pushed in neutral ?
Thanks in advance
1996 Buick skylark auto transmission
Old 06-29-2005, 05:01 AM
steve101 steve101 is offline
Re: Cant push car in neutral
frozen brake caliper or wheel cylinder or wheel bearing, just a place to start jack up each tire and see if it spins freely
Old 06-29-2005, 04:58 PM
just jacked up each side ,, not brake related but..............
drivers side spins freely in neutral
Houston...
passenger side ,, tire spins a little in each direction @ stops by hand I can see motor and tranny raising from pressure without engine running.
Old 06-29-2005, 07:33 PM
check the linkage to be sure trans is actually in neutral and not just according to gauge
Old 07-03-2005, 12:00 PM
linkage moves on top of tranny ,, I pulled right axle to push in garage.
my uneducated verdict park is busted inside tranny
Old 07-03-2005, 12:50 PM
Houston...
sounds like its still in gear maybe the linakge inside the tranny broke. i dont understand what you mean by the motor and tranny raising from pressure?
Old 07-03-2005, 03:26 PM
Re: Re: Cant push car in neutral
It must be stuck in park as turning tire forwards and backwards puts pressure on engine and tranny...
