GT Muffler
I have a GA SE '01 and i was wondering if there was any way that i could put a GT dule muffler on my SE. Is that even possible?
do you have the V6?, You should be able to, or at least i wouldn't see why not, you would just have to watch out for clearance on the rear bumper.... personally though you are probably better off getting a aftermarket like an SLP, borla, magnaflow....etc they are less restrictive and more horses, then the stock gt exhaust.
I only have like $140 is i can only go for the gt right now.
you should be able to do that. the gt model, like the se, only has one exhaust pipe from the engine to the muffler. you would need a gt muffler with the output/openings on both sides, and then the two "dual" tips. i'm not exactly sure if 140 will cover all of that, but that is definitely cheaper than the slp and borla cat-back systems which cost 500-700 dollars. adding the gt setup to your se really wont give you any performance increase, and if you get a little change in exhaust tone, it will probably be minimal. the gt setup would mostly be a visual thing, just the look of the "hot, sexy" two-sided dual tips.
Re: GT Muffler
Yeah diffently that shouldn't be a problem, since the GT exhaust actually is only a single exhaust off o fhte same muffler
Re: GT Muffler
Man i would sell my soul to get a cat-back exhaust for cheap.
