Old 06-26-2005, 08:57 AM
missatellite missatellite is offline
transmission
hi folks
my 1991 ecsort tranny is sick sometimes. when i change gears (especially when i first use the car) the gear takes awhile to engage so like when i put in first and push the gas it goes slow with the engine reving high ....so i just wait a few seconds or put it back in park and back in drive and bam she is strong like a bull ...even when i drive when the the tranny switches gears strong,seems like there is a problem with the cable or something....so i thought i would get feedback from u guys and see if this is common or if u think u know what could be wrong.
automatic by the way.......
thnx for your time
Old 06-26-2005, 11:07 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: transmission
This sounds like you could have either a dirty fluid or filter problem. If you haven't had the tranny fluid changed lately you may want to consider doing so. If you changed it recently then check to make sure the fluid level is correct.
Old 07-10-2005, 06:09 AM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
Also sounds like low fluid level. Did you check?
Old 07-19-2005, 01:48 AM
escort357 escort357 is offline
The automatic tranny in my 92 LX was acting up like that about a year ago when I got the car. Then I changed the fluid and the filter, but it didn't help. It kept getting worse for about a month or so until the tranny went out completely.
Old 07-19-2005, 11:32 PM
Davescort97 Davescort97 is offline
Escort guy
Re: transmission
Of your first complaint I don't think the pump is creating enough pressure to engage the clutch packs. Of your second complaint of strong shift, the clutch packs are worn out. Hey dude, you need a new tranny.
