Go Back   Automotive Forums Car Chat > Geo > General Discussion
Old 06-26-2005, 08:12 AM
The Russian Kid The Russian Kid is offline
Send a message via AIM to The Russian Kid
Question Prizm Harness +Hardwire +12 volt
I bought a Floor Mat that lights up form jcwhitney, now i need to hardwire it into my harness.
I opened up the panel under the steering wheel.. and i found the harness, now I need to connect the wires.
Does anyone know which color are the +12 volt that is accessory, it turns on when you put the car key into "ACC" position.
So, what are the colors of the +12 and the ground?
How do you/can you open up the harness to connect the wire?
Do you need to solder it?
Thanks in advance
~Anton
Old 06-26-2005, 11:05 AM
Akira13126 Akira13126 is offline
Send a message via AIM to Akira13126
Re: Harness +Hardwire +12 volt
The easyest way I think is to take the radio out and use the wires off that.
Old 06-27-2005, 11:50 AM
I forgot to say the car is a 94 Prizm
Old 06-27-2005, 01:22 PM
chadi chadi is offline
Send a message via AIM to chadi Send a message via MSN to chadi
yea...hes right its easiest to doit through the radio...but if you want...you can also set it up to a switch...ummm...i dont have it with me...but i bought a haynes repair manual....and i'll look it up for you....
you dont have to cut any wires to get to it...they have connectors that will do it for you...
JDM EJ8
Old 06-28-2005, 12:28 PM
OK, i think i need to attach it to the Black wire, and the negative to chasis.
will work on it today..
'We're the knights that say..."nee".'
Old 06-28-2005, 07:15 PM
Couldnt get it to work in the harness, so i hooked it up to the cigarete lighter.
got shocked several times.. but now seems to be working fine
the little block, is it a converter/amplifier?
it is making high pitched noises though.. Is that good or bad?
My self amplified Sony CD player sounds half that loud..
