Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 06-26-2005, 05:42 AM
Platapus75 Platapus75 is offline
Question Engine Build Up - GSR vs. LS/VTEC
I am completely building up a B18 block and a B16 head. Ive got the B16 head and a GRS tranny, but Im going to have the option of either the LS block and turning it into the LS/VTEC, or use the GSR block. I am torn between the two and am hope that someone can steer me in the right direction. Which will put down more power? Which is more reliable? Which will be able to withstand 10,000 rpm? Mainly plan on using it for freeway and track. Any help is apprieciated. Thanks
Old 06-27-2005, 04:55 PM
turboEKhatch turboEKhatch is offline
Re: Engine Build Up - GSR vs. LS/VTEC
Both blocks when built will handle 10K RPM's, but it's about 95% likely that your motor will not make power to 10K RPM's.
If both are available to you, go with the GSR block. You don't have to fiddle with external oil feeds, or dowel pins. The torque difference between a GSR and LS crank is miniscule at best, it makes for a difference of about 20 CC's, and maybe 2 ft-lbs of torque.
Old 06-27-2005, 08:52 PM
Kven's Avatar
Kven Kven is offline
ditto...go with the GSR block
HondaSwap | K20A.org | EF Honda
1988 Honda CRX DX
WTB: CRX mudflaps(both front and rear)...PM me if you have some for sale!!!
Old 06-28-2005, 02:06 AM
h22meangreen h22meangreen is offline
bump that. i say go ls vtec. you could have the best of both worlds. i could be wrong but i would use ls block gsr internals and gsr tranny.
Old 06-29-2005, 12:28 AM
Kven's Avatar
Re: Re: Engine Build Up - GSR vs. LS/VTEC
itll be simpler to put a LS crankshaft and rods into a GSR. GSR lower internals into a LS block=GSR shortblock that says B18B instead of B18C1.
1988 Honda CRX DX
Old 06-29-2005, 01:04 AM
duffman868 duffman868 is offline
just use the gsr block because you dont have to modify the head or theblock or deal with external oil lines. dont listen to h22
1990 Honda Civic std - ls swap
1994 Eagle Talon dl - daily driver and slow as balls
I should make a paper mache turbo and manifold.. I shall call it.. the SSAutoMache
Old 06-29-2005, 02:45 PM
Severity Severity is offline
more like 37cc's/2 cu in and 6 ftlbs
Old 06-29-2005, 03:27 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
GSR block has poil squirters and block girdle. If you put LS crank and rods in you have to machine the crank to clear the squirters. If you're doing no real modification to the block...go with a GSR block. But fi you use a B16A head on an otherwise stock GSR block, you're going to lose power, as the GSR head has smaller combustion chanbers which give it a higher compression with it's native head.
Old 06-29-2005, 08:13 PM
A 2% increase in displacement doesn't equal a 5% increase in torque
Old 06-30-2005, 12:57 AM
I dont plan on using any parts from other engines...this build up is going to have the crank knifed whether its the ls or the gsr block, arias pistons and eagle rods...plus the cylinders are going to be sleved and the head is going to have a full port and polish job done with titanium springs and retainers...im just trying to get a feel for the majority to decide which parts i gotta start looking for...
Old 06-30-2005, 10:22 AM
IMO if you're going to do all that internal work, why don't you start with something with higher displacement such as a B20B/Z?
Old 06-30-2005, 11:08 AM
Kven's Avatar
well hes going to sleeve it so he can go with a 84mm bore and just throw the B20 pistons in there(or get some higher-compression ones). at Import Builders its $100 more to sleeve the B20.
1988 Honda CRX DX
Old 06-30-2005, 11:21 AM
Right, but if he starts with a 84mm bore, he can sleeve and go bigger
Old 07-01-2005, 12:15 PM
It's irrelevant what size of motor he starts off with. The tops of the sleeves are cut away, the bottom is used as sort of the lower framework for the sleeves, and then they're pressed in. Aftermarket sleeves are the same for all B-series, save for the B16A and B17 motors which have a shorter deck height so they use a shorter sleeves, and also not including deck plate motors. If you have a B20 sleeved to 84mm by say Exospeed your motor has 81mm sleeves pressed in and they're bored to just under 84mm so your machine shop can hone them to the tolerances they prefer.
