Old 06-26-2005, 04:15 AM
br4dl3y_t2006 br4dl3y_t2006 is offline
Send a message via ICQ to br4dl3y_t2006 Send a message via AIM to br4dl3y_t2006 Send a message via Yahoo to br4dl3y_t2006
Question How to get a battery cable thru the firewall into the cab
I have another question...i went and picked up an amp yesterday and was wondering if there was a hole or a plug that i could pull to run a battery cable for the amp....b/c on my old car ('94 cavi) we had to drill a hole thru it....maybe ya'll could help me out once again....thx!
B-Radd!
Old 06-26-2005, 10:38 PM
Hoags's Avatar
Hoags Hoags is offline
Re: How to get a battery cable thru the firewall into the cab
You may have to drill a hole again, but depending on the size of the wire you are running to the amp, you may be able to force it through one of the existing rubber gromets that other wires and/or cables are running through. In the past I have been able to get a long thin screw driver through a gromet and looking undre the dash to find the driver end, I then taped the wire to the driver end and pulled it back through into the engine compartment. If you try the screw driver method, check the area under the dash where you think the driver may come through. Make sure there are no wires or anything that could be damaged in the way.
I hope this helps, good luck!
Old 06-28-2005, 09:13 AM
well its like 10 ga wire...u think it'll work w/o drilling?
B-Radd!
Old 06-28-2005, 03:38 PM
skibum1111 skibum1111 is offline
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
Thats going to have to be drilled. If you force it through a grommet, it will probably tear, and they are a pain to repair.
Old 06-28-2005, 09:27 PM
doobiess's Avatar
doobiess doobiess is offline
i actually drilled my hole for my 4 guage wire on the passenger side.. i ran the power cable up and by the window motors.. and through where the passengers foot would be and went under the carpet there..
Old 06-28-2005, 11:36 PM
Hoags's Avatar
Like ski says there is a chance that the gromet will tear, however I have been able to do it with out tearing, I have had to use a lubricant such as liquid dish soap to ease through the gromet (Not a lot just a drop or two). It's going to have to be your choice. We used to do it quite often when I worked for a automotive accessory installation place, we would run our power line from the battery to the relay fo an add-on rear window defroster. If you decide to drill make sure you seal the hole around the wire and make sure that the wire can't rub on the edge of the hole and expose the wire through the insulation. Again I can only tell you what I used to do you will have to figure out which way is going to best suite your project.
Good luck.
Old 06-29-2005, 12:35 AM
RememberTheAlamo RememberTheAlamo is offline
Send a message via AIM to RememberTheAlamo Send a message via MSN to RememberTheAlamo
Man i took off my whole dashboard, cut a hole in a gromet, and then forced the 4 gage wire through with a coat hanger. Did the same thing for my neon wires.
Old 06-29-2005, 01:01 AM
97grandamld9 97grandamld9 is offline
Banned
I ran about a 2 gauge wire throught the firewall by drilling a hold around the driverside, after i did that, i put a gromit on it then used a TON of flowable silicone to make sure no water got in. worked great.
Old 07-04-2005, 03:55 AM
hpman247 hpman247 is offline
what about a 99 ga se....any ideas...wire will be 4ga.
Old 07-04-2005, 10:15 AM
if u slice the fromet big enough u will b able to get a 4G wire in there. I got a 4G and alot of 18G wire going in and outta that gromet.
