Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 06-25-2005, 11:05 PM
bl1tzk1213g bl1tzk1213g is offline
6bolt block non-turbo
So we went to the junkyard to look for a 6bolt block. We found 2 4g63's non-turbo. Would it fit my 2g GS-T? We also found 2 G4CR came from Hyundai car that looks exactly like the 4g63 DOHC, same head. Is it possible to put a 6bolt block, just block non-turbo into a 2g 7bolt turbo car? thanks
Old 06-25-2005, 11:11 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Re: 6bolt block non-turbo
The engine from the Hyundai is a 1.8... looks pretty close to the same but isn't....My ma has a hyundai and I just about SHIT when I saw it looked identicle to my engine.... but then I saw it said 1800 on it... I laughed pretty good... then I asked her.."ya want it turboed?" LMFAO
If the engines you found were 4G63's... they are turboed... the 4G63 is the turbo motor...
The 6bolt and 7bolt are swappable...no probs as far as I know.....
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 06-25-2005, 11:36 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
The internals on a non turbo 1g 4G63 are not the same as the turbo 1g 4G63.
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 06-26-2005, 12:24 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: Re: 6bolt block non-turbo
They did make a 4g63 N/T, early 90's I believe.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 06-26-2005, 12:47 AM
so theres no chance of putting the 4g63 block? one came from a Mitsubishi Eclipse GS year 90-91 i believe. the other one was just on the ground, block and head were seperated. The only block i could put into my car is if its a turbo 4g63? thanks
Old 06-26-2005, 01:25 AM
kjewer1 kjewer1 is offline
AF - Advisor
If all you are using is the block itself, the only difference between the turbo and NT version of it are oil squirters. None on the NT block. Most poeple dont care, and the motors work fine. Others argue that its a good safety feature, etc.
The crank and rods are the same as the turbo parts, but the pistons are weak high compression POSes.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 06-26-2005, 01:41 AM
ok so N/T 4g63 would definitely fit. Can i just use the block and crankshaft and use the rest from my 2g, ex. rods, pistons ect? would u recommend N/T block with no oil squirters?
Old 06-26-2005, 03:25 AM
AF - Advisor
I can't really recomend something I haven't tried myself But I will say that enough poeple have done it successfully that I would be fairly comfortable trying it myself if I couldnt find a turbo block for some reason.
Kevin Jewer
Old 06-26-2005, 04:11 AM
hmm... Can u manually put oil squirters on NT blocks? lol it seems pretty impossible but hey, its worth a shot lol. would i suffer any pistons problems cause i mean the oil squirters are there to help the heat and stuff cause of force induction
Old 06-26-2005, 12:35 PM
Re: Re: Re: 6bolt block non-turbo
oh.. ok... I thought that the N/A was a 4G64... my bad... does anyone know about the 1800/1.8 in the hyundai's? When I saw it in my ma's car, it was wierder than hell...
Old 06-26-2005, 03:12 PM
AF - Advisor
Most machine shops should be able to add the squirters. Some poeple have had this done. It requires drilling into that oil galley and tapping for the squirters. Under 500 whp I dont think I would go through the trouble though. But again, no personal experience.
Kevin Jewer
Old 06-26-2005, 05:09 PM
so it is possible hmm... if i were to put oil squirters, can i use the oil squirters from my 2g? cause i heard 2g has different (position?) oil squirters than 1gs.
Old 06-27-2005, 09:56 PM
macder macder is offline
Send a message via MSN to macder
The 1.8L in the hyundais is the 4g67. It's similiar to the 4g63NA. Don't know the differences but I succesfully mounted a 5-speed tranny from a 4g67 to my 4g63NA with absolutely no modifications.
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 06-29-2005, 12:26 AM
How about putting a 4g64 block? will that help me fix my CW heh. i heard it will give u higher revs.
1997 Mitsubishi Eclipse GS-T 5spd stock ?
Tsudo 3" catback
Bomz Intake
HKS SSQV BOV
bcs mod and a useless boost gauge
Old 06-29-2005, 06:25 AM
AF - Advisor
It won't give "u" higher revs. You'll end up reving lower with the longer stroke, but getting more torque and airflow, and better spool. Unless of course you mean using the 2.4 liter block with the 2 liter crank, resulting in a 2.1 liter "de-stroker" that proved just a little more displacement than the 2 liter, but will rev to the moon. The biggest problem I see with those motors is finding a tranny that will shift at 10k rpm 2 liters are going to 9500 in race cars, and having enough trouble as it is.
Kevin Jewer
Closed Thread
