Old 06-25-2005, 11:32 PM
matheug matheug is offline
check engine light
can anyone tell me how to jump the connections to retreive the code for a check engine light , and were the connector is in a 1990 lasabre with a 3.8?
Old 06-26-2005, 01:13 PM
yogi_123rd yogi_123rd is offline
Re: check engine light
The following link tells how to pull the computer codes off GM vehicles:
http://www.geocities.com/dann8785/se...nginesoon.html
The connector is located under the dash under the radio/ashtray and you need not take anything off to get at it.
Old 06-26-2005, 01:29 PM
Smile Re: Re: check engine light
Thankyou yogi_123rd I retreived the code and found out it was a high temp coolant sensor. Nothing truly serious. My mind has been eased.
Old 06-27-2005, 12:44 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
If you had a code for a high temp coolant sensor it could be serious. Did it over heat or are you low on coolant? I would follow-up ASAP to find why that code appeared.
