| Let's get Technical! Discussion for hardcore in-depth motor heads! |
b18a 92 ls motor swap into a 97 civic ex WILL IT WORK???
my friend is seling me his ls motor its a 97 b18b head with b18a block and a 97 gsr transmission with a act 4 puck clutch the rest of the motor is bone stock he's giving me everything complete except i dont get a distributor or a shiftlinkage....
wich distributor and shiftlinkage will i need to make this work in my 1997 civic ex and is this swap worth 1400 |
also need to know some more stuff
is this correct on stuff i need for this swap to work on my car 94 up integra 2 plug dizzy 94 up integra shift linkage or 99-00 si linkage rear 99-00 si mount un sure on the driver side mount wich one i need for that... can someone help me out i need to know everything i can about making this swap work in my car |
Re: b18a 92 ls motor swap into a 97 civic ex WILL IT WORK???
You need an OBD II distributor
Any 94+ Integra linkage/99-00 Si 99-00 rear Si bracket. Doesn't the 97 Civic have that retard sideways mount on the driversdie?
yes it has that retard mount ..... but my friend used that mount on his dx hatch for his ls swap.... so it'll work
Ok, good then.
I hate that mount.
you will need mounts ,wiring harneess,ecu,hydro clutch , shiftlikage,
Re: Re: b18a 92 ls motor swap into a 97 civic ex WILL IT WORK???
And may I ask, when you blurt out that he needs the wiring harness, exactly which wiring harness? You do realize his car has a one piece harness, and the Integra motors have a two piece? You do realize that he is swapping an OBD I motor in an OBD II Civic? Which ECU were you suggesting he use? Being nice, so I'll stop here.
we custom fabricated the driver side mount to work.... and i used the 99-00 si rear bracket and my stock passenger mount worked fine
used stock wiring harness just cut and re wired and soldered a bunch of clips.... but was all done clean also needed different radiator hoses my stock ones were too short.... and i have the obd2 to obd1 ecu harness so that worked fiine motor started up 1st fire like a champ.... now we just need to connect the shift linkage and figure out how we are gonna make the header bolt to the cat.... the flanges are totally different |
k well drove the car... pulls fucking hard... so hard the driver side donut mount fucking exploded the rubber fucking blew out hardcore... it couldn't handle the torque or power i guess....
i'm lost on wat to do to make this shit work.... can't use that mount |
Buy a HAsport one.
Interested or not? $40 is a steel i jusat dont need it actually Give me $20 i dont care just get it out of here
