Old 06-25-2005, 06:46 PM
1992eclipseGS 1992eclipseGS is offline
A quick turbo question
If u rev ur engine while in neutral.. will the turbo spool at a certain rpm?? Or does it only spool when ur shift gears... I was told that u gotta install something in order for ur turbo to spool while in neutral.
1998 RS
5 speed, Stock front bumper w/molded urethane lip, Blitz side skirts, Bomex rear, JSP Carbon Fiber hood. Halo Projection Headlights, Escort radar detector, Turbo style spoiler, 1,200 watt sound system with 2 dual 12 subs, 20% executive tint, 17" sport rims, Custom built 2 1/2 Exhaust, OBX 4-1 Header, CAI, KYB GR-2 struts, Sprint lowering springs.
Old 06-25-2005, 07:11 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Re: A quick turbo question
any time you produce more exhaust your turbo spools....
The boost pressure is controlled by the wastegate actuator which in turn is controlled by the amount of boost....boost rises and then opens up the wastegate allowing exhaust to bypass.....something like that...he he he...
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 06-26-2005, 01:30 AM
kjewer1 kjewer1 is offline
AF - Advisor
The turbo will only spool up completely under load. There is no load on the motor when not in gear, so you dont get boost. You might be able to build a little, or at least reduce vacuum, but its pretty weak. A stutter box/rev limiter can load the motor in the way it limits RPM, allowing you to build boost when not moving. On smaller turbos like 14b and 16g I could easily build 15-17 psi at a 5500 rpm stutter. Makes launching a little more effective
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 06-26-2005, 05:27 PM
snake_canyon snake_canyon is offline
how does a stutter box work that it could build boost?
also, you probably don't need more launch power if its a fwd
