Old 06-25-2005, 06:34 PM
tigeraid's Avatar
tigeraid tigeraid is offline
Authorized Vendor
Unhappy ACK what have I done!
I knew my buddy's Nova was going to smoothly. Laid a beautiful green base coat, dried for 24 hours... laid one light coat of Testor's clear on top... looked pretty good.... lay the second coat about 15min later... BUBBLES! BUBBLES BUBBLES EVERYWHERE AAAAAAAAAAAH
So I think I laid the second clear coat too early (that usually causes bubbles right?) ... they're over most panel lines and the wheel arches, among other places... is there any chance I could sand these areas down to the green and re-clear them? Or should just start the whole damn thing over
If I do have to start over, will the CSC dissolve glue or Tamiya putty? Cuz I have a lot of custom kitbashing done here, including the rear panel (lots of filler) and glue (the damn fenders are seperate pieces on this kit.)
Old 06-25-2005, 08:08 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
No worries about the CSC- it'll leave your putty work and glue seams unaffected.
What are you using for paint? Testors clear gloss laquer over it? Got any pics...?
PHOTOBUCKET SUCKS
Old 06-25-2005, 08:34 PM
tigeraid's Avatar
Authorized Vendor
Re: ACK what have I done!
I'll get pics tonight, but the in-progress pics (before the clearcoat) are in the WIP section.
It's Tamiya primer, duplicolor GM Metallica Green, and then Testors clearcoat. I have successfully used this method on two other cars with fantastic results, so I think the clear is safe with the Testors color...
Old 06-25-2005, 09:07 PM
SidewayzS15's Avatar
SidewayzS15 SidewayzS15 is offline
Send a message via AIM to SidewayzS15
To add to what MPWR said, you were correct about the bubbles, as they usually form when you dont wait long enough. I learned something today, thnx MPWR!
Old 06-25-2005, 10:00 PM
tigeraid's Avatar
Authorized Vendor
So I guess sanding's not an option?
Old 06-26-2005, 08:14 AM
MPWR's Avatar
Re: Re: ACK what have I done!
Can't tell- let's see some pics!
PHOTOBUCKET SUCKS
Old 06-26-2005, 09:20 AM
white97ex's Avatar
white97ex white97ex is offline
Send a message via AIM to white97ex Send a message via Yahoo to white97ex
if it happened with the clear coat, i would imagine you could sand a rub it out. start with some 1500 and work to some 2000 and then rub it out. as long as it didn't eat or "etch" the lower layers of paint it should be able to be sanded away without much trouble...just a question why use testors clear? you can get the BIG can of duplicolor for a dollar or 2 more and it goes much further. especially if you are using duplicolor paints. the paint work goes much faster and smoother for me. now if you are using the testors pearl coat thats a different story...testors/model master...just my .02
My name is Russell, feel free to use it.
I'd rather be hated for Who I Am than be loved for Who I Am Not
Old 06-26-2005, 10:52 AM
tigeraid's Avatar
Authorized Vendor
k...
Old 06-26-2005, 11:06 AM
nis.k.a.'s Avatar
nis.k.a. nis.k.a. is offline
hmmm...it looks like you laid in too thick.
nightmaR3Z
Old 06-26-2005, 01:25 PM
white97ex's Avatar
i really like that color. hope you can fix it without too much effort.
Old 06-26-2005, 03:37 PM
emperorsupra's Avatar
emperorsupra emperorsupra is offline
Send a message via ICQ to emperorsupra Send a message via AIM to emperorsupra Send a message via Yahoo to emperorsupra
i use plasti-kote paints they sell them at Pepboys an i lay the clear probably 8min apart an it comes out smooth as hell
Old 06-26-2005, 04:37 PM
MPWR's Avatar
There's probably no harm in trying to sand it, but from the pics, the blistering looks pretty extensive- you're probably looking at alot of careful, tedious work. I'd say you'll probably have to use something at least as course as 2000 to get the blisters off, and then sand it back to 8000 or 12000 before clearcoating. I expect stripping is a more realistic option.
Duplicolor is a laquer or enamel? (I've never used the stuff.) If it's a laquer, you'll probably have better luck with 99% isopropyl alcohol than with CSC. It'll be safer on your putty work than brake fluid.
I'd have to say you probably clearcoated too soon. When using dissimilar clearcoat (i.e., anything other than Duplicolor clear over Duplicolor paint), the paint must be allowed to outgas completely before covering. Hot paints like laquers obviously use strong solvents, and because they're so volitile, eventually, they will all gas out (enamels are a bit, but not alot better). If the paint is covered with clearcoat before this happens, only bad things can result. Give it a week or so to be safe before you cover it.
PHOTOBUCKET SUCKS
Old 06-26-2005, 04:42 PM
white97ex's Avatar
not sure if you are talking dissimilar paints or not. but if i am doing an OOB build, i go from primer to clear in less than 24 hours. and that is working with all duplicolors, without a single problem. i dont see a need to go all the way to 8000 and 12000. i have never had a problem with shine when i go 1500 2000 and then rub it out with some 3m rubbing compound.
Old 06-26-2005, 08:53 PM
tigeraid's Avatar
Authorized Vendor
Ya, I should stress that the first coat of clear was great. The bubbling occured between the two coats of clear. And like I said, I've used this process before and it turned out great.
Old 06-27-2005, 10:02 AM
Gridgirl's Avatar
Gridgirl Gridgirl is offline
The funny (read as annoying) thing about outgassing is that there are a whole bunch of variables that contribute to the start time and duration. This means that you can have your first clear coat on, and it looks great, so you do the second. Then the ambient temperature increases, or the relative humidity decreases, or the fates decide they don't like you anymore, whatever, and the outgassing starts. The only sure way to make sure that you've let it outgas sufficiently is to give it plenty of time
