spark plugs fouled on drivers side
my 93 s10 blazer is fouling out the drivers side spark plugs
the computer is giving me acode 44 could the oxy senser being bad couse the plugs to foul out any help would be great thanks |
Need some more info to help you out; are all the plugs on the driver side fouling (1, 3, and 5), or just two adjacent cylinders?
Might want to consider doing a compression test; could have blown a head gasket. Do you have funny-colored exhaust smoke? White or Blue? If it's white, take off the radiator cap (engine cold) and starting the motor. Look in the radiator as it warms up to see if there are any bubbles in the coolant. If so, probably a blown head gasket (or for that matter, a cracked / warped head). If it's blue, a simple thing to check is to drive up a hill and coast down the other side, if you have blue smoke on the way up, it's most likely rings. If you have blue smoke on the way down, probably valve seals. Either way, start with a compression test; you can rent a tester at Autozone for free, I think. Not the answer you're looking for, but you gotta start somewhere! |
Re: spark plugs fouled on drivers side
Also, code 44 doesn't mean your O2 sensor is bad. It means it is doing its job and sensing a problem. Not all O2 sensor codes mean a bad sensor.
1995 Factory Blazer Service Manual for sale, PM if interested. |
i did read the responses that i did get .the answer to the spark plugs fouling is 135 the compression is good and it dosnt smoke until the plugs foul out it has had a new distributor when the plugs arnt fould it runs great and has all kinds o poweri belive it is a w vin
CPI and nut kit are shot and need to be replaced.
Here is some info: http://www.s10forum.com/forum/showth...pi+replacement
[quote=flippie]i did read the responses that i did get .the answer to the spark plugs fouling is 135 the compression is good and it dosnt smoke until the plugs foul out it has had a new distributor when the plugs arnt fould it runs great and has all kinds o poweri belive it is a w vin[/QUOTE
the part that you told was bad the cpi so when i go to the parts house to get this part is cpi and nut kit the propper name for this they dont seem to know what iam talking about and your help has been greatly apreciated thanks for the help
CPI Injector
Nut kit (Fuel line kit) Dealer only item Upper Plenum gasket
thanks for the quick reply this will very helpful thanks
